Want To Borrow: Suction Camera Mount Or Other Tyoes Of Camera Mount
hey guys
was wondering if anyone here has a suction camera mount that i can borrow for DECA???
had one lined up which fell through last minute and if i buy one online i wont get it till next week. and i prefer not to buy seeing as ill hardly use it.
willing to leave a deposit of some sort and details so you know i wont run off with it lol
ta
Ash
also does not have to be suction camera mount. just wanted that so i can stick the camera outside the car but an inside camera mount will do
sweet so i can borrow yours? kthnxbye
lol
have been looking around and its over $80 for a good one. can buy one but ill never use it or will hardly use it so not point buying one
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
