PART1
prept rb30 block
nitrided crank
dowls removed from crank
acl race bearings mains, big ends
crank collar with grub screw
n1 oil pump
new water pump
spool h-beams rods
arp 2000 rod bolts
wiesco custom 25/30 pistons 7.8-1
total seal gapless rings
cometic head gasket
rb25 head convertion
performance valve springs 65 pound on seat
adjustable cam gears
keford billet cams 272deg 9mm lift (intake/exhaust) non vct
porting and pollishing intake and exhaust (12 hours)
1mm over sized stainless intake/ exhaust valves
arp head bolts
$5,500ono
strut brace $60
ROSS RACING harmonic balancer $450
gcg exhaust manifold t3 flanged $400
tial 38mm waste gate,screamer pipe $250
garrett t04z with t3 gt35 flange rear housing for faster spool $1,400
turbo bag $40
4" intake with pod $50
custom front mount and piping,tial blow off valve $350
3" exhaust $300
custom MR ENFORCER plenum with trumpets
xf throttle body $600
haltech e11v2 computer $1,000
eboost 2( fitted never used) $500
6 x individual coil packs OFFERS
alloy fuel rail twin -6 entries with a -8 return $100
kirk 0410757949
Edited by grunter01
https://www.sau.com.au/forums/topic/295005-bighp-rb2530-sale/
UP DATE[/b
PART1
prept rb30 block
nitrided crank
n1 oil pump
new water pump
spool h-beams rods
arp 2000 rod bolts
cometic head gasket
arp head bolts
$5,500ono
strut brace $60
gcg exhaust manifold t3 flanged - SOLD
tial 38mm waste gate,screamer pipe - SOLD
garrett t04z with t3 gt35 flange rear housing for faster spool - SOLD
turbo bag - SOLD
3" exhaust $300
haltech e11v2 computer -sold
kirk 0410757949
  • 1 month later...
  • 9 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
