  • Replies 53
good work bec! your car looks tuff too :D
unfortunetly i wouldnt go back to tt due to what happened to me there ages ago but it looks like their getting thier shit together these days.
+1 to that ^
good work bec
cruise this weekend ? :happy:
Sounds like a bit of fun young lady...can I come for cruisies with you sometime? (it's Nato)
Oh, and while I'm here, could you post the dyno sheet please? Matt (SNIPER) just got a Lewis engine built with -7's (I think) and I'd like to compare...
Sure hun but will have to put it up Mon :D It's on my work comp ;)
And lol @ cry... Haven't tried that one! Normally just try the "smile innocently and sweetly and act like you're not doing anything suspicious" approach hahaha
I think it works best if your a girl ;)
But he is a girl isn't he? :laugh: Jokes! :D
Great result Bec from a conservative package. Remember it is your car, and your rebuild if it goes wrong. Nothing wrong with being safe. :down:
But he is a girl isn't he? ;) Jokes! :laugh:
hahaha , for the right price , maybe :D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
