Item: R33 Manual Turbo, Factory Grey
Condition: Check pictures for everything
Price: If its not listed just ask and I will update with a price.
CHEAPER FOR SOME PARTS IF YOU WANT TO REMOVE THEM.
SOLD ITEMS/Smashed:
Engine
Engine loom
Gearbox
Front brakes
Front Passengers Light
Front Passengers Guard
Bonnet
front subframe- $150
steering rack- $100
Standard Suspension - $250
rear subframe + diff - $350
front seats- $100, Drivers has some wear marks
rear seat- $50
Complete Manual Conversion - $600
Tailshaft,
Clutch pedal
Brake Pedal
Gearbox Crossmember
Manual Dashcluster
Anything else you think you might need
Doors - $400 Complete for the pair
Boot + T wing- $250
seat belts- $150 the lot
fuel tank-$50
brake master cylinder/booster-100
Front Swaybar- $50
Catback exhaust - $350
Standard Wheels - $200, tyres are JUST legal
tail lights-100 for pair
speedo cluster -150
Any more parts you need just ask,
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/295679-wrecking-r33/
  • Replies 54
hey mate, got any photos of the windscreen washer bottle?
also do you have the ashtray?
From memory the washer bottle is fine, but I cant remember is its got sold already or not.
Yep have the ash tray.
Take them both for $50 or if I dont have the washer bottle take the ash tray for $15
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929252
cool man, where abouts are you located?
im after a clean washer bottle in good nick - got any photos?
Car is not stored at my house so sorry no photos. Located just off anzac highway
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929301
Is that the washer bottle or the radiator overflow in the pictures on the drivers side next to the fuse box?
thats the rad overflow bottle. washer bottle sits in front of that with 2 pumps in it and a yellow cap
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929331
hey mate have u still got the stock steering wheel??
if so what condition is it in and how much if so??
Sure do mate, $130
From memory its in fairly good condition, there are 2 pics of it, check them out as best you can.
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929403
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
