R32 skyline
grey
145k km
auto
2 door gtst
runs well, just gave it a service.
good tyres all round.
turbo timer
16' mag wheels
pretty clean example, dead straight. no crash history.
heaps of reciepts,
the only bad thing i can say is that its missing the centre air vent.
can include a few spares with the sale.
clean un molestered example
http://s903.photobucket.com/albums/ac235/c...10112009001.jpg
http://s903.photobucket.com/albums/ac235/c...10112009002.jpg
http://s903.photobucket.com/albums/ac235/c...10112009003.jpg
http://s903.photobucket.com/albums/ac235/c...nt=09112009.jpg
$7250
well cheaper than any on carsales.com
also open to trades
Mackie
0422 905 956
Thanks
https://www.sau.com.au/forums/topic/295741-r32-skyline-7250-2door-gtst-turbo/
hey mate where are you located?
Willing to swap for an RS4 Stagea 99 model
located in sa so prob a bit hard. would have been keen though.
Swap for a VT Manual, WH stato suade interior, Pwr windows, elec seats, 18in VY SS mags, exhaust, lowered???
sounds nice but not to keen on commys sorry.
car now has 3' cat back exhaust
bilsten front struts and brand new kyb rear struts on lowered springs, looks much more pimp now than in photos
hey mate you got cash to play with????? got this 99 stagea dayz ed with cash my way???
http://www.skylinesaustralia.com/forums/Ni...S2-t294430.html
send me a message if your keen.
  • 1 month later...
hey mate would you be interested in swapping for a honda cbr250 rr with custom black paint with blue pearl flames, polished frame, full aftermarket exhaust, and work done to the carby, unrestricted model, does not sound like a 250
i can send pics if your interested
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
