Had a strange noise start to show itself.. at idle I get a pronounced whirring noise which sounds like it's coming from the top of my engine. Seems loudest above the cam covers and only does it at idle, at higher RPM it goes quiet. Also only happens when the engine is up to temp, I think. Will have to check next cold start.
It definitely seems to be loudest above the engine, rather than at the front.. so I wouldn't think it would be any of the external belts (alternator etc). The engine's done 118k and the timing belt was done at 100k by the prev owner.
Any ideas? I'll try and grab some hose and do a bit of listening to see where it's coming from but I should probably take it to someone to find out what's going on. Suggestions would be helpful :D
https://www.sau.com.au/forums/topic/29584-whirring-noise-at-idle/
It's not the clutch, it's not the injectors it's coming from the front of the motor.
Took it to a mech who agreed and said it could be the cam belt, could be the idler bearing. Also had someone else suggest water pump. But it is a belt/bearing noise IMO. Either way it doesn't look like it's possible to diagnose without pulling everything apart, and that won't happen before christmas...
Winds down? Mine will spin for a few second after the engine has stopped, that's normal unless the clutch is engaged in which case it should stop instantly.
It's not coming from the fan belt or clutch fan region, sounds like the front of the block, and if you listen closely it sounds like the noise is coming out from underneath the timing belt cover.
Mine does exactly what Damo's does and most other's do, just the gearbox turning over/clutch.... hope thats all it is.
-rb25
It's usually the thrust bearing (the bit that actually presses on the fingers of the pressure plate). In my experience it's not a critical, must-fix, sound.
Try the old screwdriver stethiscope trick(tip against part & handle to ear). You may find that it is just the aircon belt idler pulley. This is quite common and can sound like it is coming from somewhere else. Once you have listened through a screwdriver you should be able to pinpoint the noise easily.
cheers, i will try it.. hopefully it's coming from somewhere trivially nonimportant like the air con pulleys.. which isn't even gassed so I should probably just remove the belt if that's what it is lol.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
