assembled already, and first start, idle seems high, according to my safc, idle is 1200rpm is this high idle? AAC is already full adjusted, cannot lower the idle anymore
Edited by andy95'R33GTR
Did you clean the inside of the TB's before you put them back in? more importantly did you remove the thin layer of black silicon from around the TB flange? if you did you will need to reapply this.
There is a DIY somewhere on here..
i read those post...and so thats why i did not clean my my throttles, and i have a safc, air flow is 1.1 throttle position is 0 still, but i haven't run the car for long yes, maybe it needs for heat to lower the idle?
adjusted the ecu to full counter clockwise... rpm 1170 with a/c 950, is this normal??? bov still not working when i run and tested, when i feel the vacuum of the bov, i can feel the vacuum pressure but when i rev the engine, the pressure is pushing air not vacuum pressure, is this normal? please
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
