Hi All,
I have now only got a few parts remaining that I need to clear out of my garage! I'm located in ADELAIDE and can ship the goods at buyers expense. All parts are still in working order and have'nt had a problem with them at all! Reason for selling is a new MONSTER RB is being built and need this other stuff gone as it will not be used by me anymore!!
RB26 rods and pistons (2 pistons have ring land failure) would make an ideal upgrade for rb20/25 engines or just a direct swap for RB26 engines with worn/damaged rods.
th_06282009152.jpgth_06282009153.jpg$120 the set of 6
Idle control valve
th_05302009087.jpg $80
2X 235/45/17 tyres (brand new)
th_07252009236.jpg $200 the pair
R33 gtst S1 centre grill (silver/mink 2pak paint) with mesh included
th_rb26parts028.jpg $120
2 X Bosch 070 external fuel pumps
th_10092009332.jpgth_10092009333.jpg $50 each or $80 the pair
Rb26 dump pipes with O2 sensors and heat shields
th_10032009327.jpgth_10032009330.jpg $120 the pair
I can be contacted on 0400262578, or leave a PM and I will get back to you as soon as possible.
Ps ALL POSTAGE COSTS ARE AT BUYERS EXPENSE
https://www.sau.com.au/forums/topic/296105-rb26-parts-for-grabs/
OFFERS PEOLPE, NEED THIS STUFF GONE!!!
JUST TAKING UP SPACE, BETTER OFF IF IT GOES TO A GOOD HOME!!
WILL REPLY TO ALL OFFERS!
TRY YOUR LUCK, COULD BE YOUR LUCKY DAY.........
Hi All,
Idle control valve
WHAT BRAND TYRES ARE THEY ! THANKS
Hi All,
th_06282009152.jpgth_06282009153.jpg$100 the set of 6
Idle control valve
th_05302009087.jpg $60
th_rb26parts028.jpg $100
th_10092009332.jpgth_10092009333.jpg $40 each or $60 the pair
Rb26 dump pipes with heat shields (O2 sensors SOLD)
th_10032009327.jpgth_10032009330.jpg $80 the pair
THESE ARE THE NEW PRICES FOR THE GOODS UP FOR GRABS!!!
PM me any interests or give me a buzz!
Would like someone to put these parts to good use, as their just sitting in my shed and wont be used again!
Any interested parties should text or pm me on here. 0400262578.
Cheers HULI
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
