hi all,
i wanted to lower my car as its too high :( This is what i have at the moment:
Front: Distance between the guard and tyre = 60mm
Rear: Distance between the guard and tyre = 60mm
The exhaust system sits 120 mm and the front bar sits 180mm from the ground.
i have got bilstein suspension on my car. Now I want to lower the car to the legal height (100mm). What sort of brand(tein, whiteline, king springs etc) do you recommend? I have a budgets of less than 500$.
I dont have enough to spend on coilovers..and i dont go for drift/drag etc..its purely a street car.. should i wait and get a coilover and then sell my bilsteins.. ???
please let me ur suggestions/opinions..
thanks in advance!
https://www.sau.com.au/forums/topic/296122-lowered-springs/
It's not the distance between wheel and guard, you need to measure the distance between the centre of the wheel (the hub) and the wheel arch.
My Bilsteins have grooves machined in the body to adjust ride height (by adjusting the position of the spring platform). Otherwise get some Kings low springs (not super low).
https://www.sau.com.au/forums/topic/296122-lowered-springs/#findComment-4934332
id save ur money, buy a coilover kit for ur bilsteins ($300 or so) then some appropriate hyperco springs ($500) and enjoy on car height adjustment.
thanks nisskid.. wud you know any place where i can find the coilover kit for the bilsteins..???
https://www.sau.com.au/forums/topic/296122-lowered-springs/#findComment-4936672
Get addtional circlip groves machioned into the Bilsteins. 5 x 8 mm appart, then use Kings Lows (not Kings SuperLows). The Kings Lows will give you around 355 mm front and 345 mm rear. Use one circlip grove down which wil give you about 100 mm clearance on a 3.25" exhaust under the rear subframe. All up parts cost ~$300, plus labour.
Cheers
Gary
https://www.sau.com.au/forums/topic/296122-lowered-springs/#findComment-4942989
Sorry to hijack the thread, but now that you mention TEIN and KING springs I was thinking of buying TEIN S-Tech Springs for my R33 and I was wondering, they list the front spring rate as 4.1kg/mm and the rears at 4.4kg/mm, where I think the King springs are stiffer at the front than at the rears. Now you wouldnt feel the difference between 4.1 and 4.4 (I wouldnt think) but I'm just curious as to why you would have a stiffer spring at the back?
What are people's thoughts?
https://www.sau.com.au/forums/topic/296122-lowered-springs/#findComment-4943280
Cheers
Gary
thanks for the information Gary! I have bought 2nd hand king springs(4-5 months old) from a member here in the forum. After reading a few topics here I did come across the option of getting the circlip groves machioned into the shocks. The next question would be where do i go to get this done..fulcrum, pedders? anyone here who have done this on their shocks, please post here! thanks in advance!!
https://www.sau.com.au/forums/topic/296122-lowered-springs/#findComment-4943420
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
