send u a pic of what?
if it will fit my r33 gtst and u have the d clamps that cnnect it then pm me asap.
thanks
just to be clear
i want to buy a 27mm rear GTR sway bar that will fit my r33 II gtst. With the d clips and the rubber boots that go inside them.
the rear bar to my knowledge is u shaped with a kink in the straight part to go over the exhaust.
hey mate ive got the sway bar but i dont think ive got the clips and stuff that your after.
thanks will keep that in mind
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
