Is spectators allow? If so how much is gate entry ticket? Anyone know a decent hotel near by?
Thanks
go to superlap.com.au and the prices are there. If you order them online before the 13th you get a discount on entry.
no idea on hotels around there.
  • Replies 1.4k
Posted Images
its easy solved just run less front torque. the rear diffs are pretty much indestructable (only about 5% smaller than ford 9") and the driveshafts are OK but casn be upgraded.
the problem is....the more fwd, the quicker they go....so in an event like this they have to run 50/50 and hope for the best.
plenty of options for driveshafts, just jap even have billet stuff on the shelf. its the front diff that is the big issue.
where is lofty....how are you guys going with front diffs....you guys have by far the most experience with trying to put big power thru the front in circuit use.
bingo! duncan has hit it.. like you say it's easy fixed by less front drive and kinder shaft angles but then you'd end up with a standard height GTR with lots of oversteer and nice and slow...
like lofty obviously knows too basically the more front drive you can dial in the faster you go. downside is cvs breaking and if you beef them up then expect to bust a front diff or two out of the case (marks done that before but not in the 34). and with the front diff being housed in the sump assembly it's not something you can easily strengthen. maybe a full custom CNC billet sump would do it but fark I can't imagine the complexity of machining and the cost. my god man the cost!
everyone has been there and done it. garage saurus run their famous orange time attack GTR in full time 50/50. wont tell me how they get diffs to last but I imagine they limit front drive under braking too like dave explained.
as benno says mark has it well sussed with a similar system. this particular failure could be down to anything.
I hear the Panspeed RX7 is in a container and on its way, after receiving a nice freshen up, including a new Hollinger (replacing the Hewland) :happy:
More;
http://www.superlap.com.au/2009/?p=2948
Edited by Marlin
Me too mate, great things to drive :P
We're on the hunt for somewhere to test Hollywood's 32 after it's rebuild and new Hollinger in a couple of weeks. Lakeside or Morgan Park most likely. I'll make a point of checking the brakes too. :happy:
go the RWDs! The RX7s are carrying my hopes! Will be intersting to see how the NSX goes too. but the 900-1000bhp falcon I can't imagine being very competitive. Would have been better off keeping the V8 donk and spend as much time as possible tuning the car on those tyres at Eastern Creek I reckon, rather then building and fitting a kick ass I6 turbo motor.
And it would have been nice to have a NA V8 in Pro class.
pan speed RX7 is turbo, not NA 20B.
the pan speed car is one of my favourites. some pics I took of it at a Tsukuba hyper rev event. they are nice guys too.
I love the interior!
one nasty rear end!
I reckon the pan speed RX7 will be in the top 5 for sure. it's a very quick car and a good team behind it. It will be one of the quickest RWD that's for sure.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
