  • Replies 1.4k
Posted Images
Next out again at 4:30 Roy. Patience my friend :)
Lets hope all the cars having troubles can all get out there and just eek a bit more out of their cars!
And I just heard all I needed to :) Russ Jr (calling his Russ Jr as I just realised we have two Russ's driving black R32s, so Jr GTSt, Sr GTR :) ) has just pumped out a low 1:47s in his second last session! :) GO you good thing, get that std RB20 with a 2530 and about 220rwkws with off the shelf used Teins from Japan into the 46s!!!!! :)
http://www.natsoft.com.au/cgi-bin/results....05/2010.EAST.S2
times up on Natsoft
WD mark & crew gr8 effort guys.
Who is the nutter in the 200SX that took it to the EVOs and R35 in Clubsprint! Amazing effort.
All in all great effort and great times by the whole field it seems. Commiserations to those that have bent/broken things. Hats off to the Int'l guys, I am surprised therefore mega impressed by the speed of the cars! :)
And before you take a shot Neil, no, they dont have to impress me, or should care what I think. I am just pointing out that I wasnt giving them enough credit with regards to how quick there were going to be!
its all to early to make and bold statements but i was sure the tomei cusco WRX would bounce off the track being how rigid it is. it has really surprised me how well i†s gone.
also surprised to see the serea x2 car not miles ahead.
epic day!!!!
what happened with the pan speed and Berry's 34 at turn 4?
looked like berry was on a cooling lap and they got caught up cauing the pan speed off into the grass! looked interesting!!!
caught up with alot SAUers today which was good
Troy - you talking about Jacky Yick? yeah top steerer! IPRA u2L champion a few times IIRC?
Jacky Yick must be top steerer and must have a decent car under him to humble all the lunar space modules around him.!
hehe, i am kind of happy inside that a 2L rwd car on street tyres took it to the field of what i was expecting to be the R35 one make series with the Evos behind! What is hilarious is he would have been about 6-8 sec a lap quicker then me on the same tyres...FARK!
yep... i was sitting right next to you guys on a picnic blanket, until there was movement, then i ran down to the fence.... heck, i even came and asked you's about the barbecue tomoz to make sure i had sorted somewhere dry to be in the morning :) haha... spose i should have introduced maself... but thats just lame...
Oh hahaha you're that guy!
When you left I said to Doof "who was that?" he said "I don't know, I thought you knew him" then an awkward silence for a sec hahahahaha
wow... 2 full days of old mate in the tower speakin shit has really taken its toll on my head. Just when i thought I CANT TAKE IT ANYMORE!... he stops. Ah the serenity.
Someone needs to tell him it's ok to be quiet sometimes.
Did the guys in the last clubsprint group get to go back out after the Evo crash?
Was a shame Brian didn't didn't get back out there.
And that commentator was a twat. It was nice when his batteries went flat.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
