Salvo Xmas Cruise
It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue. Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas? Cheers guys
Thanks for the heads up, I have now started some watching of it. Duncan, it sounds like its slipping when shifting down the main straight. It flares before grabbing the next gear. Do you notice it when driving? Does it do it in any other gears?
Ha, I stopped running Iridiums and fancy spark plugs in RBs as they last just as long as coppers, and coppers are way way cheaper. RBs foul the plugs well before "they expire the plug"
