  • Replies 100
hey i just noticed on there website we are going on noodle night :blink: Ben can has a bowl of rice
Wednesday nights – Noodle night – any noodle dish with a glass of wine or beer for $14.00
that's ok Jas come in late were only starting at 7 not sitting down and eating at 7 ill be coming straight from work too
i hear steve gives foot massages to any chick from sau-sa who makes it to the xmas dinner
*guffaw*
-D
Then he'll have to massage Tracy's feet ... she won't say no :laugh:
Nene will be there too ... more feet to massage :(
Quoting Pulp Fiction:
Jules: Ain't no f**kin' ballpark neither. Now look, maybe your method of massage differs from mine, but, you know, touchin' his wife's feet, and stickin' your tongue in her Holiest of Holies, ain't the same f**kin' ballpark, it ain't the same league, it ain't even the same f**kin' sport. Look, foot massages don't mean shit.
Vincent: Have you ever given a foot massage?
Jules: [scoffs] Don't be tellin' me about foot massages. I'm the foot f**kin' master.
Vincent: Given a lot of 'em?
Jules: Shit yeah. I got my technique down and everything, I don't be ticklin' or nothin'.
Vincent: Would you give a guy a foot massage?
[Jules gives Vincent a long look, realizing he's been set up]
Jules: f**k you.
Vincent: You give them a lot?
Jules: f**k you.
Vincent: You know, I'm getting kinda tired. I could use a foot massage myself.
Jules: Man, you best back off, I'm gittin' a little pissed here.
Npz Roo iv.e had the committee table setup for 10 seats we can add to it i think if need be, i think we might need another seat set
Edit looks like we will need 2 more places on the committee table as i didn't account for Damo's +1, can you please count us and ring directors and get our table amended will be easier before its set
