Only the best here. There aren't any scratches on them, gutter grazing has been machined off and now has a nice polished lipped finish to it, with proper semi slicks with good to very good tread remaining.
Fronts are 17x8.5" and offset is +25, wearing 225/45/17 yokohama ADVAN A048 semi slicks with ~80% tread left, check out the pics! and the rears are 17x9.5" and offset is +30, wearing 235/45/17 bridgestone RE55S semi slicks with ~50% tread left, check out the pics!
That's about $5000 in wheels and tyres and I only want $3200negotiable for them :)
I store them in wheel and tyre bags, which all go in the garage. First in best dressed, happy to put them on hold if you're happy to put down a deposit. I'm in Sydney/Homebush and if you pay for shipping I will be happy to get quotes, organise a courier and package them, to any part of Australia.
pics pics pics click click click:
http://www.nissansilvia.com/forums/index.p...howtopic=417237
https://www.sau.com.au/forums/topic/297073-volk-te37-a048-re55s-picspicspics/
Hi Wing.... they look great. If I had the cash I'd probably snap them up!
Just on a side topic, can you tell me where you got the wheels repaired (for the gutter rash)? I have a set a bronze LMGT4's I wouldn't mind fixing but I've always been worried about loosing the original colour and finish.
Good luck with the sale :)
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
