Hi all, first post...
I recently bought a 1993 R33 GTS-25T Skyline. Everything seemed all good when i bought the car about 3 weeks ago, but now have run into a few problems.
The car seems to be loosing Oil. the oil pressure guage seems to drop significantly whenever i give it some. I topped the oil up, ran better at first, but then came back again.
There seems to be a build up of oil around the air filter.
Another thing i noticed is steam comming out the oil filler cap, when i filled up...
Car has a frount mount, 3 inch exhaust, remote oil filter, boost controller (usually set at around 10psi)
Is my engine stuffed?
Any help would be appreciated...
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/
Yeah dude what you have described doesn't sound good at all. When you say leaking oil do you mean from the block? oil filter, oil pump, oil feed to the turbo? It is running hot? I don't really trust the factory gauges hey, not to say take their reading with a grain of salt however just use them as a guide. My factory boost gauge is stuffed, it reads 0 vac the whole time boosting or just sitting at idle. But yeah it could be serious or maybe not too serious. more info dude
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-605934
Car has an aftermarket oil temp guage, which usually sits between 80 to 90 degrees, water temp is usually pretty good.
Topped the car up with two litres of oil just before and seems to be running ok, although obviously the problem isn't fixed.
yeah there's deposits of oil around the engine bay where the air filter sits...
will take it to a mechanic for a quick look tomorrow...
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-606245
didnt get a chance to take it to the mechanic, oil dosn't look to be too bad...
there is a build up of oil on the surface of the engine bay around the air filter. I pulled off the filter, there is a fair bit of oil in and around the AFM...
What does this mean, what is this an indication of?
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-607669
might be a ****ed turbo that is almost blown up, if anyone opens their oil cap when the motor is hot then yeah a bit of steam will come out as the ****ing motor gets very hot....
draining your oil and checking the colour is a good thing to do, that will at least tell you if your up for a new head gasket or not.... as for piston rings i wouldn't know most engines do not need rebuilds until at least 250 000, especially RB's as they are really strong motors...
but yeah since you dont' really know what is going on, i would take it to a mechanic ASAP, one that works with imports of course.....
also try not boosting it at all and see if you lose much oil.... but yeah driving it around daily may not be a good idea man as i have learnt in the past that if there is a problem you should sort it out before it ends up costing you too much
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-608150
is it leaving a puddle of oil under the car?
does it blow blue or white smoke out the exhaust?
2 litres is a hell of a lot of oil to have to put in... how fast does it use the oil?
what colour is the oil on the dipstick?
is there oil in the coolant?
all these would help us answer or at least point in the right direction.
Oh, and it won't just go away. Unlike us, cars don't heal.
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-608200
that maybe cause the gauge isn't connected up to the boost line ... thats what i did when i put in my aftermarket boost gauge, i was too lazy to fit in the t peice and left it not connected so it reads 0 all the time. i think that factory gauges are ok ... but aren't fast and accurate enough for some applications thats all ... eg ... theres definitely a big difference in response time with the stock boost gauge ... however is max readin is ok ...
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-608227
mechanics couldn't find any problems with it, but at the moment car is running well. after driving around on stock boost all week, i put it up to ten last night and raced my mate.
Car runs good as gold, does not seem to be any problems any more which is strange...
also just after i got the car i had a turbo manifold gasket replaced. mechanics never said anything wrong with turbo...
anyway ill see how i go
https://www.sau.com.au/forums/topic/29710-is-my-car-stuffed/#findComment-610417
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
