HyperGear Check the For Sale Section, its been covered.
Special promotion: This is our ATR43 Turbocharger. This is a high performance turbocharger engineered for RB25det engines to produce any thing from 200rwkws to 300rwkws. They are covered by 12 Month Warranty for all High performance use.
PPR From: $1250 + GST
Turbocharger catalog, Turbo kits and media gallery:
Turbocharger Hi flow service:
We can also high flow your old or blown T2x or T3x turbochargers from $800, Or rebuild from $400.
Please give us a call on 0413457185 or 0390163965 if any assistance is required.
Edited by Takahashi GTR
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4951390
Considering you can buy NEW Garretts for $1300ea give/take, and putting in steel wheels (with a rebuilt core) is going to cost you nearly $1000 for a proper ball bearing job...
You might as well buy the slightly larger Garretts (the -9's are the ones you want).
They give response virtually as factory, yet will make an extra 40-60rwkw ontop of factory items. (peak around 330rwkw, as opposed to around 280 with steel wheels)
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4951757
have you got the number for "rotomaster"
Hopefully getting steel wheels installed cost less than $2K closer to $1,5K,
if not i will get Garrett probably -7 cause the -9 i will have to folk out more money for actuators and their relatively the similar
Edited by Juan
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4953079
thanks for the info guys
weighing up the cost of a rebuild plus steel wheel ($1600-$1800) also the down time, i don't reckon it worth it
compared to getting brand new Garrett -7
Looks like im getting Garrett -7
just thinking about it makes me excited
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4953569
Well we can upgrade steel wheels for $660 per turbo including Garrett 360 degrees thrust bearing kit installed and balanced. Or $880 high flowed to sleeve bearing -5 spec.
Ball bearing -5 is $1250 per turbo brand new with actuator. -7 is $1320 per turbo Brand new with actuator. We don't currently stock -9s but will be able to supply them are a very reasonable price.
Also working with a 15 ~ 20 years old engine, I don't really find BB turbos are that reliable unless you run in line filters through them. 60% of total amount of turbos came in for overhauls are ball bearing turbos, and the age of them are also lot younger.
Garrett BB CHRAs got 2x 20thou pin hole for oil feeding, once they are blocked your turbo is dead. This is a problem, I think this is some thing Garrett needs to think about in their coming designs.
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4953979
sounds interesting!! mite get steel wheel
why does -7 cost more than -5, when -5 are the larger turbo?
http://www.turbobygarrett.com/turbobygarre...rison_sheet.htm
do you have address of your shop cause your site doesn't have it.
how much can a steel wheel be boosted, how much power do you think i'll be looking at?
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4954952
ATP ATPturbo.com.au
Advanced Turbo Performance
1198 Dandenong Rd,
Murrumbeena, Vic.
3163 Australia
PH: (61-3) 9569 4764
Mobile.: 0412 555 909atpturbo @ optusnet.com.au
ATP for all TURBO PRODUCTS - 1198 Dandenong Rd MURRUMBEENA Victoria 3163 Australia (61-3) 9569 4764
ALL TURBO - REPAIRS - PARTS - REBUILDS - SALES - NEW & USED TURBOCHARGERS for ALL TURBO CARS INCLUDING FORD MAZDA NISSAN MITSUBISHI TOYOTA
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4955080
Hey mate, I have steel wheeled turbos with 360 degree thrust bearings in my GTR at the moment cost me around $1200 all up, running 17psi and 287RWKW and I think thats about as far as you can safely boost them and keep them in the efficiency range. To tell you the truth I regret for not getting new Garrett's like R31Nismoid suggested for the price they cost. They just seem to take forever to spool, its much laggier than stock and die of in the high RPM range, and they cant make any more power than this. Just spend a little extra and get Garrett's and be done with it, trust me you wont save much by going the steel wheel way, I'm saying this because now I want to upgrade and have to go through all the shit to get them off again and spend much more than what I would have if I got Garrett's straight away and its not fun mate. I also think -9 are the way to go and they are the ones I'll be getting in the future.
Cheers
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4955656
^ Great feedback mate, exactly what people "theorise" about, but to hear that you personally feel a solid different is very much worth noting.
If you are just doing steel wheel's they should almost be identical in spool though.
Juan, -5's should be more expensive by around $50ea. Could be out of date pricing.
Always get a quote locally and go from there. Plenty of SAU traders doing solid pricing on Garrett Turbos.
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4955771
looked onto the garrett website http://www.turbobygarrett.com/turbobygarrett/
Noticed they have two type of "-9"
this one has the name GT2859
http://www.turbobygarrett.com/turbobygarre...9R_707160_9.htm
This one as the name GT2860
http://www.turbobygarrett.com/turbobygarre...0R_739548_9.htm
Both of them are "-9", which one are you referring to R31Nismoid.
the first one doesn't come with an actuator,
whilst the second does come with an actuator.
https://www.sau.com.au/forums/topic/297366-turbo-rebuild/#findComment-4965272
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
