Originally posted by [ABU53]
dude, most workshops etc do them.
i have a mate who can make them oh, and also, i know that ARES SPEED in brissy can do basically any design/brand
ssshh .. dont tell boxhead! he will want in on the rice too :) it will go well with his high powered nismo window sticker :D
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-51785
Chucky
I can do the sticker for you at a good price in whatever vinyl you want just let me know the brands....
$8 each for normal size ones
HKS
APEXi
BLITZ
TEIN
BOMEX
PUNCHED OUT CAT (DRIFT CAT)
CUSCO
FALKEN
OS Giken
C's
EBC Green stuff
GReddy
GAB
Central Circuit
"Street Racer" in Japanese
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-51926
All depends on the vinyl and how you remove them. You should never use chrome or brushed alloy-look vinyl if you want to save your paint due to the amount of heat transfer....normal plastic vinyl is fine so long as you wash the car regualy.
When removing them leave the car out in the sun for a while so the vinyl softens up a bit then remove. I have never had a problem....also depends on the condition of the paint.
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52098
Sorry Cam, didn't mean to try to outsmart u there. I read 'in HPI' a little blurb explaining that the so called punched out cat was actually the URAS monkey. After some research, I found that it isn't true and that HPI screw up more often than not. (see link for proof)
Sticker looks good though....not too big.
"Can I have one"
"No"
"Can ....Lenny have one"?
oh yeah, I'll buy one btw
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52820
Actually, here is some contradicting evidence.....i been doing more research and have been finding more info that suggests the 'punched out cat' is the URAS monkey!
eg: http://www.uras.co.jp/2001tokyo.htm
http://www.uras.co.jp/goods.html
anyone who can help me out with this one??? Cam???
Its really bugging me now
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52828
From what I understand the PO Cat was originally drawn on cars by drifters after an accident....most likely, Uras actually took the PO Cat and stylised it as there logo due to the amount of drift cars they build. The question is simple, do you want the PO Cat like I posted? If so just tell me how high you want him and on what vinyl and I will make it.
private email me to discuss payment etc.
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52859
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
