Hmmm .. Fire walls hacked?
nope. only problem is getting the bonnet to shut. Get a vented bonnet or chop a hole in the standard one. RB30s are the same size as the 25 n 26 the only difference is the RB30 is taller.
https://www.sau.com.au/forums/topic/298024-i-am-new/#findComment-4960428
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
