Rb25det + Rb20 Ecu With Nistune + Gtr Injectors, Need A Resistor Pack?
Will I need to fit a resistor pack to raise the impedance of the GTR injectors? or will they work fine on the rb20 ecu with nistune?
I still have the rb20 loom and fairly sure the rb20 ignition system as well (car is an R32). Currently it is all run off a wolf3d V4 which I imagine has impedance matching drivers but I want to upgrade to a nistune (it is a rubbish ecu and wont pass an inspection).
Anyone know?
Thanks :P
On a stock ECU you will need the resistor pack.
I believe with a NISTUNE you also need a resistor pack.
My mates RB20 had gtr injectors running of a nistune and that had a resistor pack.
Unless you can get it setup for low impedence
I found someone with stock injectors, fuel rail and fuel reg so Im gonna install the lot. I will just leave my waste gate unbolted so that the car doesn't boost and lean out Once I pass the inspection I'll put it all back with a resistor pack.
Can anyone detail how to make a resistor pack and how I should install it ?
Thanks again. :P
Thanks again. :P
I considered making my own resistor pack ( being an auto elec), but for like $100 its easyer to just buy one.
Im unsure what sort of Power(watts) they consume and have never felt a GTR pack after a thrashing to see weather they get hot.
To make one that can supply 6 injectors, and not generate heat, also keeping the overall size as small as possible might not be easy.
If you use formula P=IxV you can work out what sort of Wattage resistor you need to decipate the heat, providing you have the voltage and current. say on average it would be 13v, but i have no idea what current will be flowing.
Then get someone to measure the resistance of the resistors in a GTR pack and you will find out what resistors you need.
If that makes sence?
But hey give it ago if you want.
I'm actually a computer systems engineer so I am sure I could make one, just need to know the specs if anyone has them. If it is only $100 I might just buy a set though, anyone know who sells them?
Edited by Rolls
Look through the forsale thread. I have heard you can get them new. and from memory the price wasnt too rude.
If you end up wanting to make one i can get you the specs as i have 1 sitting in the shed.
If you could that would be tops, can't be too hard, just be 6 massive 5w resistors surely ?
Thanks again. :)
Have a read through here on how I installed the resistor pack.
http://www.skylinesaustralia.com/forums/Gt...l=gtr+injectors
Thanks for that, what is the 'ballast' resistor? Do you know how many ohms it needs to be and how many watts it should be rated to? Also why have you seperately wired it to each injector, couldn't you just cut the red wire and put it inline with it?
Edited by Rolls
The ballast resistor is the GTR resistor pack. Which has 1 voltage input and 6 injector outputs.
The red wire (12v power) also provides power to other parts in the engine (from what i remember?) so thats why you have to find the actual 12v wire for each injector. As shown in the picture, a wire splits off the red line which then powers three injectors.
If you are going down the resistor path, I believe you just wire the resistor inline with each 12v injector wire. The tricky bit is determining which one is the 12v from the 2 wires running to each injector connector. My method is to use a multimeter to find the 12v instead of stripping the whole loom to find it.
There is another thread on this forum which explains which resistors are needed from jaycar.
Hope the above makes sense? haha
Yeah it does I just wasn't sure exactly what the 'GTR resistor pack' was, and if I was to make my own what ohmage and power rating the resistors need to be. I will do a search for this thread you mentioned.
Edited by Rolls
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
