Hey All,
I know a few of us are participating/watching this event on Sunday so I thought I'd organise a meeting point and time for those who want to cruise up as a group. It takes around an hour and 15 min to get there and we should arrive a bit early so we can get ourselves organised and fill out paper work etc.. We will be leaving at 6.40am SHARP so don't be late. Here it is...
Where: Shell Gateway servo at EPIC
When: 6.30am arrival for a 6.40am departure. SHARP!
What: Cruise to Maurlen Driving Training Center
Please add your name to the list if your intending on meet up so we know who and how many are coming. Cheers...
Frink
was an awesome day! everyone drove well with only a couple of cars having dramas. big ups to reece for having the showdown of the year with me!! was close buddy, but i think i won that round!! we were dicing so closely that the officials told us to separate! Zane did a great job too. in fact everyone did. was good to put some faces to names as well. thanks too go out to stinkypoo for taking some happy snaps. cant wait to see em!
some good pics there stinky... you can see the marshal about to tell me and reece to move apart in the last photo. we were much closer than that on previous laps :D. And if any one wants to know how much of a difference brake ducting makes than look at the 1st photo. if you look closely my rears are glowing and my fronts aren't! i do recommend it for any trackdays you might do....
You definantly won that round, but was hell of alot of fun, I will try to even the score next year. RS-R's and a Diff to come to level the playing field :down:
THANKYOU so much for the photo's to both Stinkypoo and Callum, great reminder of the day. And thanks to Zane for almost embarrasing me in me own car, .4 sec isn't a lot of time to find :)
  • 1 month later...
Better late then never, or maybe better never at all, I dunno.
I've uploaded a very short clip of ALL of the HD footage I got on the day. Check it out here:
http://teamredstage.wordpress.com/2009/12/...ush-video-clip/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
