this was a great day out last year!
This falls on cricket grand final weekend, so i cant confirm my attendance until early March!
Hopefully SAUSA will have a display, we will discuss at the next meeting.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
