Doing a favour for one of the nurses at the hospital.
She needs someone to drive her son to his year 12 formal.
To keep things to the point, he is the only man in the house.
Can a fellow member please help out.
Pickup before 5:30 Fadden THIS FRIDAY
Arrive at destination (town) by 6:00
Basically an 'on the way home from work' type of deal....
Show this good kid a reason to have a big grin on his face!
I know its not much notice.
Please contact me on 0404 577 263 if your keen to donate an hour of your time.
My R30 will be in Sydney along with myself (would of done it but hey)
Cheers,
Andrew
https://www.sau.com.au/forums/topic/298745-formal-request-number-2/
evening:
update.
national convention center at 6:00pm is the drop off
hoddle place fadden is the pickup, 5:30pm leave residence
pink is fine to me, BUT the young fella preferrs non pink cars. (thanks mel!)
hope this gets some bites!
cheers guys
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
