  • Replies 102
Posted Images
All parts off an 1989 R32 GTR with minor front end damage. Located in Adelaide. Willing to post at buyer's expense. If I haven't listed an item u are looking for, ask.
Engine/Mechanical
Plenum & Throttle Bodies $300.00
Standard Block $700.00
HKS 2530 Turbos approx 10,000k's old $2,000.00
Exhaust Manifolds $50.00
AC Compressor $120.00
Power Steering Pump $100.00
Alternator $50.00
AAC $50.00
Coil Packs x6 $100.00
Ignitor $50.00
Covers (minor crack on front cover) $300.00
Crank Pulley $100.00
Turbo Oil Water Lines $50.00
CAS $120.00
Tomei Camshafts $500.00
Greddy Cam Gears x2 $200.00
Windscreen Wiper Motor $40.00
Brake Master Cylinder $50.00
Clutch Master $50.00
Boost Sensor $30.00
FMIC Piping x4 $80.00
BOV x1 and adaptor plate $50.00
Cross Over Pipe $50.00
AFM's x2 $140.00 (2 Sets)
HKS Pod Filters and piping x2 $80.00
Gearbox $500.00
Front Diff/Sump $300.00
Power Steering Reservoir $30.00
O2 Sensors x2 $50.00
Engine Wiring Loom $200.00
Injector Resistor Pack $50.00
Fuel Rail $40.00
Clutch and Brake Pedal $30.00
Accelerator Cable and Pedal $50.00
Windscreen Washer Bottle $30.00
Front Driveshaft $40.00
AC Condensor Fan $20.00
Standard Clutch Fan $40.00
Starter Motor $100.00
Interior
Dash Cluster 280kph (No Brand) $150.00
Front Seats (wear on driver side seat) $500.00 (pair)
Rear Seat $100.00
Momo Steering Wheel & Boss $50.00
Instrument Cluster Surround $30.00
Door Cards $60.00
Dash Loom $100.00
Carpet $80.00
Roof Trim $80.00
Center DIN Guages $80.00
DS Window Control $60.00
Sun Visors $30.00
Boot Trim $50.00
KickPanels $30.00
HICAS Computer $50.00
Gearshift Surround $40.00
Center Dash Trim $40.00
Rear 1/4 Trim $40.00
A Pillar Trims $30.00
Center Console $60.00
Door Garnishes $50.00
Interior Lights $30.00
Dash Windscreen Demister Vents $20.00
Glove Box $30.00
Fuse Box Cover Interior $30.00
Drivers Footrest $20.00
Heater Unit $40.00
Climate Control unit $80
Suspension & Brakes
Brakes & Rotors $500
Front Driveshaft $100.00
Brake Booster $30.00
ABS $180.00
Tailshaft $150.00
Steering Column $150.00
Steering Rack $150.00
Exterior
Passenger Side Headlight $120.00
Boot $100.00
Passenger Guard $100.00
LHS Door $130.00
RHS Door $130.00
Windscreen with RVM and in built antenna $200.00
Rear Window $150.00
Sideskirts $50.00
Wiper Arms $30.00
Fuel Tank $150.00
Tail Lights $50.00 each
Genuine GTR Rear Wing $100.00
Passenger Indicator $20.00
Rear Bar $50.00
Cowl Pane l $40.00
Reverse lights $30
Clutch lines $40
Side mirrors $50 each
Rear Bumper $80
Prices on some parts may be negotiable but within reason.exterior parts factory silver. Any questions, post or pm or email [email protected]
Remaining pics are on their wa. Let me know if you want anything specific.
do u haev the interior panel for quarter windows?
plz email me at
[email protected]
interested
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
