Hi Toshi,
I am in Perth and currently have a R33 Skyline with exhuast, fmic, pod, apexi neo (safc) and greddy ebc - dyno tuned making 193 rwkw (260hp) the car does seem to have a large mid range flatspot - what power would you expect to get with a ecu remap for my car? and will it get rid of the flatspot?
Cheers,
Steve
Hi Toshi,
Cheers,
Steve
Normally around 200kw at 12psi.
I am able to fix flat spot .
Much smoother than s-afc.
Dear Toshi,
I live in Sydney and was wondering do you tunes on the spot.
I have an R32 GTS-T with turbo back exhaust, r34 smic, airfilter, walboro fuel pump, sard fuel pressure regulator and a vg30 turbo (off single turbo 300zx). Making dismissal power at the moment, needing tune drastically.
Please let me know quote for bring you the car (if option is available) tune etc.
Chris.
Dear Toshi,
Chris.
Hi
I sent PM.
Thank you
  • 4 weeks later...
My customer got 207kw AFR 12 street chip
R33 GTST S1
split dump turbo-back exhaust with hi-flow stainless steel cat. Kakimoto racing muffler (very quiet)
splitfires, cold spark plugs.
FMIC
Greddy Profec Spec B- 12psi
Remapped ECU chip by Toshi
277hp -207KW
Do you dyno tune or road tune? Where abouts in Sydney are you and what is the rate for a tune, car has nistune and i have the software and cable.
I can road tune or dyno tune also dyno and road tune both.
Im north ryde.
Please tell me what is your car and mods.
Im north ryde.
Stagea s2 neo manual. FMIC, hi flow cat, gcg hi flow turbo, larger exhaust, split dump, EBC and nistune.
Hey Toshi
I have put a S2 RB25DET into my HR31 coupe with the folowing mods: fmic, 3 inch turbo back with no mufflers, boshi 040, greddy profec type 2 boost controller 8 low and 13 high psi, k and n pod and standard afm and injectors. I will be getting splitfires in the near future too. Also it was origionally an auto. What type of power should i be expecting? Can you pm me a price for the ecu tune and any other info?
Thanks mate
Adam
Edited by KDS_HR31
  • 8 months later...
I will make ecu remap according to your car modifications for R33 R34.
Price from only $400 now.
If you are not happy I will money back
If you are not happy please send back in two weeks.
Otherwise I can not refund money.
Hi Toshi,
are you able to Remap a series 1 rb25 for garrett GT2876R, denso 550cc injectors, z32 afm, bigger fuel pump and aim for around 260rwkw on 1-1.4 bar ?
Cheers charles
Hi Toshi,
Cheers charles
Where are you living?
odd request here
can you do a tune for a series 2 manual stagea? but, tune it for 95ron fuel?
pod and 3 inch turbo back exhaust, thinking about going up to 10psi in the future
i'm down in tassie and bp ultimate is about $1.70/litre
thanks
I am planning to visit Melbourne around end of this month or next month(Jun or July)
Anyone interested in tuning?
R33 Cost $550 road tune
Please call 0410490049
Or [email protected]
  • 3 months later...
Hi Toshi,
You come highly recommended from a number of people I've spoken to, so I thought I'd ask:
I have an S1 R33 GTS-T, standard turbo, ECU, engine, etc. All it really has is a full exhaust, FMIC, and an Apexi AVCR that I have running at about 10psi (sometimes it gets to 11-12, and sometimes I switch it to "OFF" in the rain).
I've got the stock ECU in it at the moment, and while I live in Sydney, the car lives south of Wollongong.
I'm not after huge power, just something that gets rid of that "flat" spot in the middle of the stock ECU :) And makes the car a bit more fun to drive.
Would the mail-out ECU swap work out best? ($400 I think it was?) I'm just not too sure what to do; I've previously had a Power FC, and I was getting 202.1rwkw on it at around 10psi.
Thanks for any help!
Yes,std turbo is $400 exchange mail order tune.
If possible to come to me , I am able to real time road tune $550.
I think better for you.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
