Hi Toshi,
I am in Perth and currently have a R33 Skyline with exhuast, fmic, pod, apexi neo (safc) and greddy ebc - dyno tuned making 193 rwkw (260hp) the car does seem to have a large mid range flatspot - what power would you expect to get with a ecu remap for my car? and will it get rid of the flatspot?
Cheers,
Steve
Hi Toshi,
Cheers,
Steve
Normally around 200kw at 12psi.
I am able to fix flat spot .
Much smoother than s-afc.
Dear Toshi,
I live in Sydney and was wondering do you tunes on the spot.
I have an R32 GTS-T with turbo back exhaust, r34 smic, airfilter, walboro fuel pump, sard fuel pressure regulator and a vg30 turbo (off single turbo 300zx). Making dismissal power at the moment, needing tune drastically.
Please let me know quote for bring you the car (if option is available) tune etc.
Chris.
Dear Toshi,
Chris.
Hi
I sent PM.
Thank you
  • 4 weeks later...
My customer got 207kw AFR 12 street chip
R33 GTST S1
split dump turbo-back exhaust with hi-flow stainless steel cat. Kakimoto racing muffler (very quiet)
splitfires, cold spark plugs.
FMIC
Greddy Profec Spec B- 12psi
Remapped ECU chip by Toshi
277hp -207KW
Do you dyno tune or road tune? Where abouts in Sydney are you and what is the rate for a tune, car has nistune and i have the software and cable.
I can road tune or dyno tune also dyno and road tune both.
Im north ryde.
Please tell me what is your car and mods.
Im north ryde.
Stagea s2 neo manual. FMIC, hi flow cat, gcg hi flow turbo, larger exhaust, split dump, EBC and nistune.
Hey Toshi
I have put a S2 RB25DET into my HR31 coupe with the folowing mods: fmic, 3 inch turbo back with no mufflers, boshi 040, greddy profec type 2 boost controller 8 low and 13 high psi, k and n pod and standard afm and injectors. I will be getting splitfires in the near future too. Also it was origionally an auto. What type of power should i be expecting? Can you pm me a price for the ecu tune and any other info?
Thanks mate
Adam
Edited by KDS_HR31
  • 8 months later...
I will make ecu remap according to your car modifications for R33 R34.
Price from only $400 now.
If you are not happy I will money back
If you are not happy please send back in two weeks.
Otherwise I can not refund money.
Hi Toshi,
are you able to Remap a series 1 rb25 for garrett GT2876R, denso 550cc injectors, z32 afm, bigger fuel pump and aim for around 260rwkw on 1-1.4 bar ?
Cheers charles
Hi Toshi,
Cheers charles
Where are you living?
odd request here
can you do a tune for a series 2 manual stagea? but, tune it for 95ron fuel?
pod and 3 inch turbo back exhaust, thinking about going up to 10psi in the future
i'm down in tassie and bp ultimate is about $1.70/litre
thanks
I am planning to visit Melbourne around end of this month or next month(Jun or July)
Anyone interested in tuning?
R33 Cost $550 road tune
Please call 0410490049
Or [email protected]
  • 3 months later...
Hi Toshi,
You come highly recommended from a number of people I've spoken to, so I thought I'd ask:
I have an S1 R33 GTS-T, standard turbo, ECU, engine, etc. All it really has is a full exhaust, FMIC, and an Apexi AVCR that I have running at about 10psi (sometimes it gets to 11-12, and sometimes I switch it to "OFF" in the rain).
I've got the stock ECU in it at the moment, and while I live in Sydney, the car lives south of Wollongong.
I'm not after huge power, just something that gets rid of that "flat" spot in the middle of the stock ECU :) And makes the car a bit more fun to drive.
Would the mail-out ECU swap work out best? ($400 I think it was?) I'm just not too sure what to do; I've previously had a Power FC, and I was getting 202.1rwkw on it at around 10psi.
Thanks for any help!
Yes,std turbo is $400 exchange mail order tune.
If possible to come to me , I am able to real time road tune $550.
I think better for you.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
