My Car came with a Nakamishi CR/Tuner (Single DIN) and Nakamishi (Single DIN) Mini Disc player.
From what I understand Nakamishi is a pretty good brand of stereo - Well in Hi Fi anyway - I didn't know they made Car Audio stuff.
So my question is - How good do these band expanders work ?? Is it worth while doing to this unit ?? As I have a fairly new Sony Head Unit that I was going to put in (cause I didn't expect to get a good stereo with the car).
If I take the Nakamishi out, not sure if the Mini Disc will still work with the new Sony.
Also, I have 2 Amps (One for Main Speakers x 4 ) and one for Sub - Don't know if these will work with Nakamish or not as I'm not sure if the Desk has 2 x RCA outs. (I know my Sony does)
Anyhoo - Help is appreciated.
https://www.sau.com.au/forums/topic/2990-band-expanders/
There are more than one brand of band expander out there, and some work better than others - so make sure you don't buy a crap one if you are going to get one...
At a cost of around $30 to $50, it is a small price to pay even if you only use the Nakamichi head unit for a few weeks and then decide to go with the Sony or whatever...
https://www.sau.com.au/forums/topic/2990-band-expanders/#findComment-51883
Guest mooks66
hey brendan.
if you dont wannt the naka anymore, PM me i'll come pick it up off ya right away dude. k?
as for band expanders... weve got em at work and theyre a sinch to put in..
havent got my car yet, but yeh, i'll let you know how it goes. i'll be putting one in.
they cost around $40 bucks
cheaper if you work there of course hehehe
https://www.sau.com.au/forums/topic/2990-band-expanders/#findComment-54348
Mooks,
I'm gonna get a Band Expanda for the Naka - I'll see how it goes - If it doesn't work with my existing kit (Kicker Amps, etc) Then I'll be looking for a home for it.
I'll post how I go with it all.
Thanks all !
https://www.sau.com.au/forums/topic/2990-band-expanders/#findComment-55066
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
