Hey boys need some help
I want to replace my stock r33 sidemount intercooler with an aftermarket high flowing cooling item.
Not interested in front mount yet cause i dont have aftermarket turbo. If i get a front mount this will be defected by police unless i have an engineers certificate and car has been emission tested.
i have spoken to an engineer about this so i know the facts.
I need to know if any one is making custom coolers to replace the side mount in original position. I have heard that some side mounts are good for 230kw.
options for SMIC
1.R34 bolton cooler
2.Trust aftermarket
3.ARC aftermarket
Surely there are companies out there making efficient SMIC to replace the standard units. Im not interested in return line intercoolers painted black as cops can spot this and defect you if you dont have certificate.
Defecting is huge in NSW and im sure if we can get some good performance items for our skylines yet maintaining the stealth look more people will follow the trend. Face it guys cops hate jap imports.
Any advice or recommendation greatly appreciated.
if you plan on running standard turbo with 10-12psi, the r34 side mount will do, even the r33 side mount will do the job. all you really need to work on is getting loads of airflow to it by making some kind of vent.
once you upgrade exhaust and get a tune you will then need to start thinking about getting a front mount or some kind of o2 spray jets installed on a bigger side mount. the more boost you're running the less time air spends in the cooler which is why we go for front mounts - they are efficient coolers vs. $$. on a side mount you will need a o2 or a water spray kit installed to keep intake temps cool. good thing about these kits is they run on solenoids so if you're cruising around town where you dont really need it you wont be using up your water/o2, whereas if you hit the track you can dial it in and it will offset the need for a front mount.
anything bigger than a stock turbo then you will need a front mount.
even the best SMIC on the market is a POS, ive tested ARC SMIC on both skylines and S15's and can assure you they are junk. The cores heat sink after no time and are less effecient than most of china FMIC's ive seen come through the shop.
Now i now for fact you can buy a return flow FMIC and have it Engineered (last cost on engineering was $700) here in vic for about the same as the ARC RRP...
Edited by URAS
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
