My dash top gets so hot it's a wonder that the instruments work atall does anyone know where I can get a dashmat for an R34GTt from dont mind paying to have one fabricated but I don't have a clue where to start looking.
Any leads or ideas anyone ?
Edited by BASHO
https://www.sau.com.au/forums/topic/299130-hot-dash-need-mat/
going on your other post if you get a dashmat your automatic lights wont work nless you get that piece of the dashmat open... if you park your car in the sun during the day id suggest to use one of those window visors... much better security wise aswell... and carpet on your dash doesn't look the best in my opinoin
Automatic lights?
The centre LCD lights on my climate control unit and in my head unit appear to be controled by a sensor during daytime running which dims them down to the point of being unreadable Space Goat has kindly advised me where this sensor is (left hand corner of the dash as you sit in the drivers seat) it looks like a small, about 10mm diameter, solar panel.
I am going to gleefully cover it up to see if it will undim the two LCD panels so I can actualy read them in the daytime.
the sensor does not seem to control anything else and I have no idea if there is any on off control for it though there may be something in the climate control unit if I could only figure it out. :)
Interesting - I've been reading the R34 Workshop manual and they talk about an 'automatic' setting for the lighting switch - but I'm buggered if I can find anything like that. Playing with the sensor on the dash seems to do nothing with interior or exterior lights - maybe mine's busted? I might have to run through the diagnostics in the manual - but without having this switch in the 'automatic' position, I'm not sure it's going to help me...
its climate control sensor, unless you have a aftermarket alarm or light sensor fitted
use the silver faced sun shade, the dash mat looks crap , even custom ones
At the risk of being labeled an ignoramous WTF does the climate control sensor actualy do ? I have on off temp variable aircon and ?
There is no auto switch (at least that I can find) to control the centre LCDs lights though they will brighten if you go into a dark area from daylight but during normal running daytime they're crap I can't see squat.
I use a sunsahade whenever it's parked in the open, farkit it's Qld, but driving around the dash top gets hotter than a burning witches tit and I don't give a rats if it looks crap , I tend to agree actualy , but it'll diffuse the heat and thats gotta be worth it.
:D
dash mat might look a bit crappy but it will mean that in 10 years time the dash won't look like crap. i have always used them in all my cars (except my 2 imports) because they also reduce a bit of glare off the dash and make it a touch easier to see out the windscreen at certain times of the day when the glare off the dash reflects up onto the windscreen.
as for where to get one made, go and talk to the people at your local autobarn, etc. they should have a supplier that will make custom mats and may be able to make one up for you.
Cheers, I'll givem a go :D
I got one for my R33 from these guys last year: Accessories Online
They dont list R34, but it would be worth asking. Where I was working meant I had to park in the sun all day and the mat helped alot... Yes it comes with the sun sensor cutout...
There is also a CF mat available I saw on Yahoo Auctions a while ago, but I cant find it anymore...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
