  • Replies 115
hahaha i know your guessing but from that pic how can you see the axels that go through the engine sump :) really up high there is no difference from gts4 to gtst
he can put an attessa switch in instant rwd without dropping a shaft
I said that because R32 GTS4's came standard with ABS, and it doesnt have ABS. Yes it could have been removed, but for example Dans R32-R which has been de-ABS'd still has reminants in the bay..
But youre absolutely right, I cant see the axles through the sump :(
Come on Tangles, confirm what it is!
edit: it has staggered rims too........
The R32 sedans were offered with four-cylinder and inline-six engines, of which the basic was the CA18i, a normally aspirated 1.8l 4-cylinder with 91hp at 5200rpm (GXi). Next was the RB20DE, a 2.0 l normally aspirated inline-6 with 155hp, for the Click for a larger imageGTS. Top of the bunch was the turbo-charged RB20DET, with 215hp/6400rpm and 263Nm/3200rpm of torque, which worked in the GTS-t and GTS4 models. Later, the GTS25 also got the RB25DE, a normally aspirated 2.5l inline-6 with 180hp at 6400rpm and 231Nm at 4800rpm. 4-speed automatic and 5-speed manual transmissions were available. The automatic even came with a so-called “power”-mode, in which the box holds the lower gears until about 5000rpm, instead of the usual 3000, before shifting up a gear. For the first time in a Skyline, power was fed either to the rear via a viscous limited-slip-differential, or to all four wheels (GTS4). On the passive side, ventilated disc brakes all around with 4-piston calipers up front and 2-piston calipers in the rear kept this power in check; ABS was available optionally.
Source
rebuilt Rb30 gearbox
that wont last long. start shopping for a 25 box.
i knew someone was gonna bring up the whole higher RON thingy...but who cares, LPG is still homo lol
~60-70 cpl, 115 octane, how is it homo?
I don't rate LPG... Yes its higher ron whatevz but imo its wack as f**k. Epic converters needed if you want to run decent power, another tank install makes for a very messy setup. I'd only consider it if I had big $$ for alot of custom parts to hide all the condensors otherwise makes your bay a mess, and if it was a Drag only car. Tubbed, caged, 4link etc.
Congrats on the buy man, its going to be a ball of fun. Having a RB30 gearbox you would think its RWD? lol
That gearbox won't last long. They sturggle with stock RB30ET power. If its the MX7 (genuine turbo box) It'll last yyou some time but dont expect a MF5 to hold up long after a couple powerskids lol.
P!ss them wack rims off asap too :)
Edited by Weezy
i dont know what your talking about :) lies all lies
comes with spare GTR gearbox, so all is good
rwd, petrol, six&ahalf G, done deal, on early flight tomorrow to melb, home tomorrow night.
* happy pants
:P
dent to fix. got a longer seat rail on order already :D
already have my previous decent new 17's rims, a new seat I didnt like in the Stag, etc.
bit's to do, but gonna be good fun.
all in lieu of the bike - which I have used for like 400kms only.
so yeh a good deal to keep me happy.
The new direct port gas injection is a good piece of gear. All the new holdens and fords have to use the new system because of their ECU. The new systems give you the same fuel control as multi point fuel injecton and can make some really good numbers.
Brett for Graham West got around the 340rwkw mark with their XR6T with just a slight boost increase and LPG.
thread fail, need advice on r32 gtr and you go and get yourself a gts tangles tangles tangles
sorry
:P all I can "afford" seeing its in lieu of having a bike
already got attessa in the stag - now have GTR rb26dett & gearbox
might find its way in - ? :D
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
