I'v only got boost set on 12 pounds, cooler, Apexi RSM and turbo back 3inch (gutted cat) and it pulls in third very quick and there is constant power all the way to 253kmh in fifth. i used to have flat spots even a splurt but got it all worked out on dyno and the less restrictive ur exausht the more flow. 1st and 2nd are a waste, tyres lighte up all the way and seriouse speed comes in third onwards. trust me, dyno is worth it.
Wish you were closer so we could have some roll ons to compare and see if the 1.5 pounds more does much, i have a very restricted 3 1/4inch system keeps the police off my back! Is 253kph red line or just wont pull anymore?
late second gear (over 4500rpm) all the way until say 1/2way through 4th is where i kill every car but i very rarely get to go into 4th (Its just to fast to be safe).
most cars pull away in first gear (even with a good launch) coz they are either V8's or 4wd Turbos or pocket rockets but once your 1/2 way through second you catch them very quickly, usually u catch them before the redline in 2nd, then 3rd you just pull away :D
i have never tried this with my new EBC, it will be interesting to see what its like :D
I have too much in third and start to wheelspin on coarse road surface at 100kmh. Wheelspin in the wet also at 180 in 4th too if I floor it. Modified stock turbo from Rigoli but mostly stock with 0.5mm OS pistons. Dump pipe and IC are stock for now but 3" zorst and hi flow cat. Power comes on like a sledgehammer at 4000 so maybe thats why it does what it does and only at 11psi. Bit laggy though under 4000 and have trouble staying with stockers through the roundabouts out here. The straight bits inbetween make up for it and the handling but slow out of tight corners.
I use an EBC @ 0.62bar (full boost @ 2900) and i found if i hit it hard in third, it gets a bit overwhelmed with fuel (or something?), so if i just ease it in (over 1sec) it responds alot better and seems to 'avoid' the flat spot.
weird stuff.....
-rb25
25
which controller do U have and what do they retail? I could use some of that!!!!
That seems consistant with 'lines that you have to feed the power as they go soft at pull pedal when running the std computer. Anyone else experience this?
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
