Hope you guys can help me.
I have a 1994 r33 gtst rb25 with a full 3inch exhaust, greddy profec2 boost controler and K and N filter running 100 octane fuel with stock smic. I have bosch 040 fuel pump. On 10 or 12psi the car ran well but over a period of 2 weeks it began to misfire and develop flat spots.
I have recently replaced the platinum plugs 1.1m with a set of NGK bcr6es coppers gapped at 0.8. I have also siliconed up my coil packs as well.
The car runs really smooth all the way to redline with out misfires or flat spots, even at 12psi. The problem is that the car feels alot less responsive in power delivery, smoother but slower in acceleration. Could the problem be the gap on the plugs or the fact that they are cheap coppers. Im thinking that the spark in the chamber is alot smaller causing less of an ignition and thus killing some power. What do the experts think.
Ideally i want it running as hard as before with the smoothness and lack of misfire it has at present.
https://www.sau.com.au/forums/topic/299330-spark-plug-problem-in-rb25/
Hey manuel im no expert unfortunately..... Um so even with the less responsive power delivery do you think you have actually lost maximum power in the car or....?
Um I think that gapping your plugs to 0.8mm should give you a faster ignition so the only thing I could think of is that the timing is slightly out. Maybe its firing slightly earlier and not at its best position. But I knew someone who gapped it to around 0.8mm aswell and he thought he had a slight increase in power with similar mods to yours. Like I said I no expert I'm just throwing up some ideas.
"waits for someone to correct me"
"6" heat range should be fine, considering the factory spec is a "5".
The gap has no effect on the "speed" of ignition, so the timing will not be affected to any significant degree. The type of plug is pretty much irrelevant. Pt plugs are used standard because they require less maintenance and a longer replacement interval than Cu plugs. In all other respects, they are the same - they simply provide a facility to ignite the fuel / air mixture inside the combustion chamber.
Try opening the gap out to, say, 1mm. This should provide a stronger spark, and therefore a better burn of the fuel/air mixture.
Or maybe you are just used to the power delivery, and there is no problem at all.
Sorry 'blind elk' I think my term of faster was a little misleading. I was told by a 'performance' mechanic that when increasing the boost in the car and making more power you should decrease the gap of the plugs to give you a more reliable spark especially at higher RPM? So I was thinking that with a larger gap the plug had the tendency to possible 'miss' or be delayed slightly due to the speed of everything at higher RPM's and thinking logically, smaller distance = quicker time to get there. As I said im no expert just throwing an idea. After all this forum is a place to learn something for us noob's haha
After doing a little reading I do agree with your point of getting a stronger spark and better burn at a larger gap.
you are correct in what you say about the smaller gap giving a more reliable spark. a bigger gap at higher boost can result in the spark being blown out, so to speak.
blind elk is correct though about a bigger gap being better. the bigger gap means there is a bigger.... lets go with fire front. the spark has a bigger surface area when arcing across so is able to ignite more fuel in it's duration. will it result in more power though? not enough to notice unless you were running seriously rich, but that would also make the bigger spark less reliable.
as for the feeling of a loss in power, has the weather been hotter when you are feeling the loss of power? that will make a big difference in power, especially with a SMIC. in summer the stock cooler will suffer from heat soak extremely quickly at 12psi, resulting in a loss of power. you could probably drop the boost to 10psi and not lose much power on a hot day.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
