the last few months i've had nothing but problems with my R33 . Right now i've got this stupid idle issue when the car is hot, not when its cold. What the car does is it starts fine and revs and a nice steady rate, but as soon as you blip the throttle anywhere past 3000rpm the revs go under 500 to around 0 then bounce up to 500 then back to 0 sounding like a rotory and pissing black smoke trying to save stalling then it goes back to normal. Ive cleaned my AAC Valve 2 times with good carby cleaner , new gasket for the AAC valve , New Plenum gasket , Ive cleaned the throttle body and i've positioned the TPS to what is says in Nissan RB25 workshop manual which is 0.40v. I've got a brand new Bosch 02 genuine and just bout done everything . I've searched every forum and NOBODY is having the same issues! .. I've adjusted idle with the gay TPS unplugged like it says in idle and im running PowerFC so i cant adjust it on the ECU .
NOW the only way to stop the rev hunting issue when i rev the car is to adjust that scew thingo that pushed the Butterfly open or closed on the throttle body , so my car revs at 1500RPM and eveything is fine! it revs nice and comes straight back and sits on the rev and doesnt drop! . The car even feels better to drive as it doesnt stall when i boost 1st gear and then back to neutral ..
But the only issue i dont want my freakin car to idle at 1500!!! i want it to idle at 750RPM at the most..
Not one mechanical workshop knows what im talking about and probably half you guys wont but there must be a solution before i run this car off the cliff and sell the scrap
https://www.sau.com.au/forums/topic/299402-idles-drops-when-rev/
I already moved that thing!! where should it be? it doesnt state it in the manual??? and i already said i cleaned the AAC Valve 2 times? and i mean really cleaned it with freakin cotton wool buds and carby clean+ compressed air! .. what else can contribute?
its your blow off valve and its called pcf disease . do a search
how about you do a search under the description i have wrote? you wont find shit! i just want my freakin car to work and my blow off valve was blocked off in the test and did the same thing , i just tried my stock one and it is the same so its not that
My car did a similar thing with warm starts with the PowerFC where it would hunt. I ended up using datalogit to try to relearn the start up procedure but it got worse. Took it to the tuner and they said it was leaning out which was causing the problem. They fixed it up and ever since its been fine.
Edited by Penfold
its either your bov or if you have bloked off your bov and the recirc pipe is bloked off aswel it will do this just set ur idle to like 800 from the powerfc settings not the way you did and it will be alright
I have had a similar problem on 2 occasions
1) it was an air leak, check all your piping
2) dead airflow meter and busted wiring to the AFM
Cant promise your case is the same but it would be worth checking out
there is a new thread every week along these lines . its either an air leak ( block the afm and pump up the whole system with air compressor ) or its power fc disease . it it to do with air reversion back out the air flow meter . when you rev it up engine sucks in air when you let off the air has to go somehwere some goes out the blow off valve or in your case it all goes backwards out the air flow meter and as the air flow meter and ecu dont know the difference between air flowing in and air flowing out it sees air going in and puts lots of fuel in .
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
