If thats LEDA suspension and Brendale, the guy is a legend! He has done most of the work on my dad's clubman. Really knows his stuff, build lots of purpose built race cars, like sports sedans, all his knowledge is from experience not a how to hand book. Very good, and reasonable, realistic prices. He has worked on my mini and was very happy, haven't taken the line there yet as I moved to the Southside and it a bit of an effort to get there.
Hows about Gold Coast Suspensions. (07)55914488
They specialise in Drag and Race/Rally units and are Import and Electronic suspension specialists.
Do very good work apparantly (haven't been there myself, but have heard good things)
Fulcrum parts are good (car has all their bushes installed) , but they over charge like you would not believe for labour. I got a quote to change by struts and springs, come in at $400 so a mate and I did it in my driveway in under an hour. The longest part was compressing the springs with they would have done using a rattle gun.
Buy there stuff and have installed elsewhere.
Agreed, I got my shocks and whiteline gear through them, but when I asked how much to install, I nearly fell over. So I went home and did it myself in two hours and got a wheel alignment afterwards. They are good just their labour is hell expensive.
thanks for the suggestions.
however, I have decided to just get the settings I need from the last place that set it up (in sydney) and will just get the local bob jane to tweak it as required.
out of curiosity, which suburb is Leda in?
Leda is in Strathpine/Brendale, probably a bit of a drive for you. I went there this morning to get a new threaded spring seat machined for my coilovers. They are very good. I always like walking into a workshop with rollcages and race prepared shells lying around. I usually deal with Ron, the other guy in there is Bruce.
Last time I used Bob Jane they did a pretty average job, the cambers were out by 1/2deg on each side. They said it was worn bushes which was shyte as I had them replaced just before.
I'd suggest using Tyre Tech in Albion for general setup etc. The guys there are brilliant and most of them race. When they set up the car it was 1.37, 1.38 from left to right. In other words "Spot On".
do these places deal with just 'normal' skylines ?
i need to get the camber on my rear tyres looked at badly
Whats normal? I have taken the mini and the gemini to Leda many times. Great guys. He had a nice 180B in the mix this morning too!
I am sure if its possible to reco the coil-overs it wouldn't be a problem, have never asked them to do that, a spring is a spring so springs shouldn't be a problem either, you tell them the spring rates you want and I am sure they could organise something, I highly doubt they would get Jap brands though. They do heaps of custom suspension work with clubmans, hot rods and building full race chassis, I am sure any problem with a road car could be solved.
i am thinking of fitting my coilovers at accurate suspension. anyone had any experience? is leda better? does anyone know the advantages of weighing each corner? should this be done with driver in the car? do most suspension places have the C-wrenches to adjust the height. mine are ohlins coilovers, are they different from say, tein or gab?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
