Hello,
I'm interested to know from anyone that has or knows of people running a R34 Plazmaman Plenum with after market ECU and Turbo " 3540 " Etc
Anyone here making over 300 - 400 RWKW From Plazmaman R34 Plenum? Or have Dyno reports
Thank you
Edited by dsrturbo
https://www.sau.com.au/forums/topic/299653-r34-plazmaman-plenums-hp-out-put/
The plazmaman plenums are rated at something like 800HP-1000HP of air flow aren't they? So i doubt they would be a resctriction of any sort if that's what you are asking.
Edited by PM-R33
get a life and go read the rb25det dyno results thread
What on earth is up with this comment??? Seems "reading your previous posts" your not a happy guy.
Has anyone actually made over 3-400KW with this Plenum?
Edited by dsrturbo
Well you can make that much power on the factory one mate... so you would very much hope an aftermarket one would do the same now wouldn't you? :(
But yeah, you could just read the dyno results thread. Look at the part list... then look at the power made... you then answer your question with a bit of your own self help :D
I'm confused, what are you actually worried about? It not flowing enough air to support that power? As Ash said, the stock one can flow that much power, so one twice the size obviously will.
These plenums are capable of flowing 1000+ HP. Not only will you experience instant power gains , but you will have the capability to maximize future modifications .
Quote from Plazmamans site.
The plenum isn't going to be a problem anywhere near those power levels.
I have a er34gtt with pon cams, pistons, exhaust gear, rods, link g4,ross balancer, plazma plenum, 3540.82 turbo. 70 pound springs.
At 8psi car makes 275 rwkw. Increase the boost to 17ponds it makes 285kw..
Weve done pressure tests in Exhuast and intercooler and cant figure out why it wont make power. Today i tested the valve springs and none of them are spungy -all fine at 70+ pounds.
I need to rule out the plenum and to do that im asking t see a 400kw or less er34gtt.
Car should make 330+ Kw at 14psi and 380+ at 19 pounds. As our partners cars have with the same turbo using a er33 engine.
Maybe r34 just cant make power.
Next to do is the following:
1. Dial in the exhaust cam.
2. Backpressure test the exhaust manifold/turbo inlet to determine ratio of inlet/exhaust.
Edited by dsrturbo
You are expecting to get 380+rwkw from a GT35R with a 0.82 rear? Is this a Rb25/30 or just an RB25?
Same turbo on r33gtst engine is making 330 at 14psi. Using a r32 Computer and 300zx air flow meter and de cam shafts. Hub Dyno. Same Dyno, same tuner
Even at 17 pounds Engine should be making more power than 285. Its only 10kw difference and yet 9psi Increase.
Above comments Is next to do
Edited by dsrturbo
I think that .82 housing is going to stop you from making 380rwkw, but we shall see. Back to your original problem.
The plenum isn't the problem. You got any dyno graphs you could show us?
When you say you tested the exhaust and intercooler, did you drop the exhaust at the dump/cat to test that?
^ hub dyno's is not RWKW mate. Lukas - that is why he is higher than normal.
If boost goes up, power does not = exhaust restriction most of the time.
Have you even dropped the exhaust from the dump/front pipe and seen what happens? (im dubious of this "pressure" testing you've done when its as simple as 3 bolts)
Are you 100% sure the cam/gears are all dialled in correctly?
Yeh dont take the exhaust off at the turbo and test haha. I also think that the 0.82 will restrict you from that power level. Are you 100% sure they aren't running a 1.06 rear housing or something? Have you checked that your cat hasn't collapsed?
We put a pressure tester in the oxygen sensor hole and did a run. The result was 2psi. Could be better but that is not the problem
Ah ok well then that makes a lot more sense.
Piston Compression test no not yet. Possible cause. But i asked Tuner and he sai unlikly. CP and pauta rods. Will test tho next run ( no smoke or problems - tuner would pick up ? )
huh? I was just wondering if the cat had collapsed. hahaha sorry if you thought I meant do a compression test.
Cam gears dialed in will be done next. However tuner has asked other tuners advice and they say if car makes 275 on 96 octane at 8psi. It should have no trouble making more power dialed or not. Im pretty sure the dynaPack Dyno is in rear wheel kw. I will have to ask about this?
Edited by dsrturbo
Cat like catconverta? It has no cat it has been removed. VT has been turn off and on with no significant difference
Right now its a odd ball. Because alot of money has been spent on te engine to only make 275kw :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
