Cat like catconverta? It has no cat it has been removed. VT has been turn off and on with no significant difference
Right now its a odd ball. Because alot of money has been spent on te engine to only make 275kw :D
Yes catalytic Converter. Ah ok no cat....hmmmm. Have you tried seeing if it makes more power when you disconnect the exhaust from where the cat used to be? How bad is the pressure drop over the intercooler?
Cam gears dialed in will be done next. However tuner has asked other tuners advice and they say if car makes 275 on 96 octane at 8psi. It should have no trouble making more power dialed or not. Im pretty sure the dynaPack Dyno is in rear wheel kw. I will have to ask about this?
96 octane... are you from America or similar?
Hub not equal to rwkw. You take the wheels off mate :D
275 on a HUB @ 8psi sounds about right however for a GT35. Anyway, that's not the main issue here!
If the timing is not correct mate, you can have issues making power, most certainly.
Hub not equal to rwkw. You take the wheels off mate :worship:
Shell and Caltex in NZ is 96 Octane. We have Gull and thats 98 Octane. But is over 1 hours drive away.. We were running up on 96 and then doing a final tune on 98. But never got that far.
definately not the plenum...possibly the plenum install if there is a leak...
how is boost through the pull? does it stay constant or drop off a fair bit?
droping the exhaust for a run is the best idea as is doesn't really cost you anything and can rule out a component.
you'd also want to have the cams dialed in as they are a fairly important part of an engine and can see a range of differing results... which cams have you got?
I have 1 Tomei exhaust cam gear. Im hopeful that changing this will do something. Also the plenum, i removed yesterday and have purchased a new gasket to rule that out. The Exhaust tip is a oem nismo er34 unit and has a restrictor in it. A Small Armour All Spray bottle it to fat to poke up it. I think its 2.25" Diameter. But still pressure test was 2psi so.. Will suggest losining off the exhaust front pipe
Gasket is two weeks off from nissan nz / jp. Some bit of a wait ;/
Im hopeful we will get everything sorted by next time round. Here are a few pictures now taken of the exhaust "3" and what not.
Bit of a over dose with Silicone on the plenum..
I will take care of the silencer pictured by taking it to an engineer to saw off the tip. Remove the silencer. Take out a pcs of the silencer. Pop it back in. Weld the tip back on and after alot of $ will be good as new
Edited by dsrturbo
Ok um...but what cams do you have. As in what camshafts :rofl: 2.25" is bloody small! I think my exhaust is going to be too small for the 25/30 with a gt35r so 2.25 is pretty small. I know you say the pressure test said 2psi but I still think you should just drop the exhaust and measure the power output. Please :D
Fuel system? Pump? lines? pressure tested @ [given psi]?. What rail you using? are the injectors maxing out? is it IW or Ex?
Not he fuel pump and Injectors. Have a inside fuel guage ( greddy thing ) Tomei pump sard 800 or 850cc injectors. Maybe there Denzo.
Cams are Pon cams. Will see what happens second time round. 2 weeks away :rofl:
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
