Hi
Just want a quick answer cause I have been searching and couldnt really find much and want to order some silicon hoses now
Just want to know what outside diameter the STOCK throttle body and STOCK turbo inlet is, or better yet what size silicon hose will slide on properly lol
Thanks
https://www.sau.com.au/forums/topic/299828-stock-rb25-tb-and-turbo-inlet-size/
nooone? Im fairly sure for the throttle body I'll need a 2-3/4" Silicon hose but i cant get to the turbo to measure it. someone must have a stock one laying around that they can have a quick measure for me, even if it is only a rough measure
pretty sure the inlet of the turbo is 56mm OD
so a 2 1/4 coupler will fit it.
and the throttle is 70mm and a 2 3/4 coupler will fit.
Dont quote me, but im pretty sure theyr correct.
go to super cheap and ask them to try a few sizes in the carpark, bring an 8mm ratchet with ya to get the hose clamps off.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
