12.601 @ 120.2mph on bp ultimate in full st trim with full tank on st tyres. Am i happy or what. I was also running 3-4psi less then what it was tuned at. Wait till i get full proper slicks. Oh touch it.
H.
If you don't mind me asking what sort of full proper slicks are you thinking of using...Brett
sounds like it was good fun
soon as my cars back on the road you can sign me down !
i want to do some runs before i add IC, AVCR and Dump Pipe + a few other things.
So ive got a point to improve on.
Somewhere around January 25th the car should be ready :(
rnz11z i saw you there but u were yackin away to others so i didnt say hi.
yer another 13.9 for me, guess it reinforces the fact that it wasnt a once off thing.
crossing the line at 103 mph, its all in the 60ft
i did 2 other runs with 2.3 sec 60ft and they worked out to be 14.1s and then a 2.2 60ft and it was a 13.9
so if i could get a good launch, i could get a good time
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
