Just wondering wat does a air filter do to your car? does it make it go any faster or does it save petrol or anything, just one of my mates recommend me get one, just can you guys help with this, because he said that its not good for my car me to have a sports exhaust/muffler system n no air filter (as one ive got no is preety old...11yrs)
any help wuld be great
thanks
https://www.sau.com.au/forums/topic/30060-air-filter/
man, you can have whatever combo you want... it's not that it's "not good for it"... you'll just get more performance with the whole lot... an after market airfilter sucks more air than a standard one and the more air you can get into your engine, the more performance you can get out of it...
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611268
You'll get a small fraction more power, but you'll let dust, dirt, pollen, insects etc into your engine which will make it wear out prematurely. So you'll get more power for a while but then things will become worn, compression will drop and you'll end up with a shitter.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611323
That's after it's done a nice bit of damage to your compressor wheel :( Checking the turbo wheel on any car you're about to buy can be a good way of seeing if a decent quality air filter was used on the car.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611324
thanks
nah, you dont need an air filter, get rid of it :(
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611426
waaaa?
if u buy a descent brand Pod Filter than your air is filtered the same as the airbox, just think of a pod filter as the airbox inside out kinda
u get what u pay for, buy shyt.. get shyt
bugs and dirt etc? ide love to see dirt or bugs get thru my K&N pod, actually i wouldnt see them if they were that small neways, not to mention theyd get burnt instantly with no trace or damage if they got that far into the engine
make sure pod is attached properly etc too
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611429
waaaa?
also think about the $170.00 defect notice from police if its not properly enclosed.
my 2c...not worth it without a proper box and cold air induction.
better off staying with the stock box that is a good heatshield and has a CAI and replace the element with a hiflow one..
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611432
now thats a better idea, put a pod in the stock airbox :(
but cmon u cant say dont put a pod filter on there cos cops with defect u for it, haha
in the many time ive been pulled over not once have they asked to see under my bonnet
on the topic of 'defects'
u do know changing the frontbar, exhaust etc is a defect too
now tell me u dont have ne of those or the 1000 other ones :)
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611444
Surely changing exhaust is legal? I mean, you go and get a stainless exhaust from Midas and you're changing your exhaust, yet of-course it's legal? PODS are another thing all together.
I have a POD, custom one made for me on my little Alfa 147. I've positioned it pretty down low, not so low that it's going to suck up water on a wet day, but low enough for it to get a lot of cool air to it (IE far away from the manifold/engine).
AND WOW! It sounds absolutely amazing. Growling, low rumbling noise on open throttle. It sounds better than my newly aquired R32 GT-R!!! Easily, the Alfa is a noisy little revvy car. I am so tempted to whack a pair of K&N pods on the GT-R but I'm not going to do it :( Keeping this baby stock.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611450
It's a pretty major operation to put a pod in the stock airbox. It can be done but some mods need to be made. That's why most people remove it when fitting their pod, and why aftermarket pod boxes are so readily available. It's easier to fit one of these than to mod your original box to fit the pod.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611451
ofcourse it is
But franks was talking about the defect fine or whatever and then suggested pod in a box.. which takes you around the pod filter defect problem :(
changing the exhaust is a defect if u dont have an emission test and certificate for it im fairly sure, the rules are different in diff states but last i herd this was the case. I certainly havent got mine tested, and i have changed my front bar, and pod filter and about 10 other things hehe
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-611483
ok, yer cos i was looking at gettin a k&n one on special for 79.95 and my bro can install it, so does it make it sound better with the exhaust cos i got a 2.5" exhust system.
and is it worht getting a CAI done aswell? does it make much power i heard between 5-15kw's
let us know what you think
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612462
no, i wasn't implying put an aftermarket pod inside a stock airbox, i am saying, replace the stock air filter element (inside the stock air box) with a high flow one.
here are my findings when i replaced my apexi super intake with a stock airbox and hiflow element.
http://www.skylinesaustralia.com/forums/sh...t=stock+air+box
on the notice of defects, you live in brisbane! theres the difference! performance cars in sydney are targetted all the time. i goto RBT's and i've had them ask me to open my bonnet.
on the subject of aftermarket exhausts, in sydney, as long as it complies with certain emmission tests and noise levels ie. under 90db they are fine. i believe you can goto an RTA inspection station to have your emmissions and noise checked for free.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612498
GTRboy: they're easy to install you could do it yourself....
There's 4 screws where the AFM connects to the stock airbox... undo these and take the stock airbox out...(you may have to take the top off and the filter out to do this easier..) Thes, screw your adapter plate for your pod on there, and your pod goes on your adapter plate and you tighten the ring clamp up with a screw driver... it'll take you roughly half an hour but don't be worried or anything its easy and if you do it yourself you'll save the dollars and boost your confidence with working on the car...
cheers man.
https://www.sau.com.au/forums/topic/30060-air-filter/#findComment-612503
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
