Hey everyone, around february or so im getting a group of cars together to go to WSID and to have a bit of fun. They want to go to the track and test the cars to their full potential. I want to see if any N/A skylines would be interested in going, or really any N/A car that isnt over 6 cylinders(trying to keep it somewhat fair).
Current cars going:
My 300ZX -catback,pod,chip,UDP 131.4rwkw 5spd man - will have SAFC+tune by then
VR V6 - Bellmouth removed, Catback, Intake(pod,cai,tb pipe) 4spd auto
SSS - Catback & Pod - 5spd man
Lancer 1.8L Sedan - 4spd auto
Lancer 1.5L Coupe -Catback, pod+tb pipe - 5spd man
2004 Magna ES 3.5L - Stock - 4spd auto
Alfa romeo 156 Selespeed - Auto
Cars MAYBE going:
VL N/A - exhaust,pod, extractors - 5psd manual
300ZX Targa - pod - 4spd auto
I'm doing this in february as thats the earliest everyone will be free to go. Also as most of us are new to this, expect a bunch of 17 second slips :):(
yes yes, the P plate brigade is going to race, but atleast we're doing it legally! ;)
Edited by Super Drager
https://www.sau.com.au/forums/topic/300867-wsid-drags-would-any-nas-wanna-go/
i might come if my car has all the body work done and i get new tyres. Cant go on the track with 2 semi slicks and another too that are mesh at the front =\ ANNND if i can hit the 5000km mark on the odometer then i will be able to push the car so i dont damage the new engine.
r33 GTS4 - RB27DE ( 50 thou piston upgrade) ... and a pod thats it! Kw ~Unknown~
Good on you guys for organising events like this.
It's great to see the stereotyped car enthusiasts getting out and having fun safely, and legally :(
Yeah, i'm trying to get a bunch of N/A's together and just have a good time and compare slips afterwards. So far the commodore & the magna are the only cars that look like they'll be a challenge. The commodore isn't like any other V6 one i've been in, it has stupidly high bottom end power and keeps up with higher powered cars very easily. Would be fun to get some quick N/A lines and supra's there along with whoever wants to go. If you have a turbo and want to show up feel free, i can get two or three other turbo R33's to come aswell.
YES! that sounds like it'd be pretty quick so if you can, show up.
I might be up for this.. Only ever been once with my 34 ran a 15.0, 15.1, 15.3 with my old bilsteins and crappy tyres that got too much wheel spin and 3" Kakimoto Full mega exhaust,
Got new suspension and might feel like giving it a proper go with or without new tyres to get under that 15 sec margin. Still painfully slow
Preferably go after the 15th so ill have the money.. haha
:):) lol hope the road aint wet :):woot:
im just gunna rock up lol
It's great to see the stereotyped car enthusiasts getting out and having fun safely, and legally :rant:
+1 guys. The track is great. Good to see some smart young blokes still exist haha.
:(:( lol hope the road aint wet :(:)
We all know cheap $199 semi slicks are not aloud on my car ever again! Toyo Proxie T1R's are more like it!
Yeah hopefully if jason helps me finish the car off it will be down in my car :)
Once i buy my list from NENGUN it should be a lot better.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
