Hey Everyone
I been thinking for while of getting a FMIC, but now that ive starting looking into it theres alot of different sizes and core dimensions etc...
I have a series 1 GTS-T M-SPEC will the FMIC fit without much mods to the front bar?
Just wanted to know what other people have put on and dimensions please.. my Budget is about $2000 installed i dont want to blow my budget.
Im also getting the exhaust done dump pipe and high flow cat any recomendations on that would be great also!
Thanks!
https://www.sau.com.au/forums/topic/30089-fmic/
You have to cut the bar for any decent sized fmic. I haven't done it myself but the workshop that installed the fmic did so without too many dramas. I don't think it's that hard.
Dump pipe and cat - get one of each from BATMBL! See the car parts trading forum.
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-611765
I'm thinking of putting a GTR cooler on mine... I figure i only wanna run around 12-14PSI (GTR runs that) and it should virtually bolt straight on no worries...
Plus I only wanna take the car to a max of around 200RWKW (for the time being) so the GTR cooler should do the trick...
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-612668
Dimensions i think are around 600x300x70 (but don't quote me on that. Piping work is easy, just take it an exhaust place and they'll get it done for you for around $300-$400.
Sounds like a GTR intercooler will do the trick!!! Thanks alot Guys now have to start find one for a good price.
What u reckon is a reasonable price? $500-700??????
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613350
If you don't want to cut the front bar yet still get good performance out of the IC use a Bar and plate.
Mine fits perfectly behind the front bar.
Its rated at its optimum of 580hp with a 1.5psi pressure drop.
From memory its got 60-63mm inlet/outlet 2.5", 600 x 300 x 90. I think.. :D
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613384
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
