id luv the new Navara STX alot more $$$ but with a big load behind them almost feels un noticable. i also agree with a few posts above, turbo diesels. luv that torque
Yeah but i believe thats not a tray ute...
And also i overheard a guy at toyota trading his not old stx for the hilux cause it wasnt powerful enough
Edited by doozooby
I've just recently got a Ford Ranger turbo diesel. While i wouldn't say it's top of the range, it is a great value for money ute.
The ride isn't as refined as perhaps a hilux (I wouldn't know for sure cos I haven't driven one) but that may also be because I opted for the hi rider model as I wanted the ground clearance.
As for reliability you cant beat Toyota build quality, particularly the Hilux. Diesels too are very longlasting hardwearing engines because of their more robust design. The advantage in drivability in a turbo diesel is huge, pulls easily from 1500 rpm with plenty of torque, not so much power for landspeed records, but the ability to move easily no matter what you're carrying.
you do know the ford ranger is just a mazda BT-50 clone with electric windows, both are great workhorses
Yes I do, exactly the same under the skin.
Both made in Thailand for the Australian market actually
Haha just found out my accord was made in Thailand too...Anything else...with all the tourism included im surprised they are not taking over the world
the way i see it is;
those guerrilla forces in the jungle use hiluxes to get their troops around, hiluxes are everywhere in the middle east and have to deal with dust and sand storms constantly - as well as constant heat, in thailand they all use hiluxes to transport trannys and top gear tested the shit out of one and it still didnt die.
whats the moral of the story kids???
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
