Invite ~ March 2010 ~ Haunted Hills - Classic Skylines Australia Attack!
This is your official invite to attend and compete in Classic Skylines Australia's First Hill Climb for 2010 we had a few 180's and 33's come out and play in the Rain last time so would love to see some more in what should be a Dry day, (fingers crossed) looking forward to a great day out!
______________________________________________________________________
The following is cut and paste from CSA Forum
CSA are heading down to Haunted hills for what should be a DRY ATTACK on the track,
Limited spaces as always as this even fills up Fast!
This will be your last chance to get points for the CSA championship
CSA Hillclimb - Haunted Hills Gippsland
Date: 7th March
Time: Gates open at 8am, Scrutinizing 8.30am, Practice Runs at 9am.
You will require a CAMS or AASA license to compete.
Links:
http://smokie.ws/Newtrack/index.htm
http://classicskylinesaustralia.com/thefor....php?topic=15.0
Prices:
EARLY BIRD (Till Feb 3rd 2010): $90
After Feb 3rd: $115
Invite your friends from other clubs all are welcome,
  • 4 weeks later...
  • 1 month later...
Hi,
Is there a web page or map that shows the location of the track, has information for spectators: event start/end time, admission fees, etc...
JH
I'm taking one of the Lancers on Sunday. First HH for me, should be great. I've heard so much about it.
Is there anyone else heading out there thru' Dandenong on the morning?
Will be great to see the evo out and about,
There is a meet going at 9am but thats too late, a few of the organizers are heading up for an 8am arrive time, should be departing from freeway sports center, ill let you know the details when they are all together tomorrow if you like
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
