Good to see an R33 GTS run 12.3 on wed night with 306rwhp on good rubber.
This car was only a 25/40 bolton turbo, Wolf plugin ECU, intercooler + exhaust.
Can't wait to see ND4SPD run now it has 280hp more than this GTS at only 21psi and soft timing,we have left it soft because we have to race Tango1 on tuesday at the plex and didn't want to upset the commish of police.Then we can put good fuel in and crankit up.580 is the highest power run by a GTR on a Shootout accredited dyno in WA sofar!
https://www.sau.com.au/forums/topic/30182-whales-revenge/
  • Replies 65
Make me a coffee and i'll tell you.
Wait till the 2 Bar runs happen next week but remember that this power was in Shootout so don't be suprised when Ant beats "Higher" powered GTRs.
Wheres the Cams Toddler?
I drove ND4SPD today,F--k the 9000rpm limiter hits very fast in the first 3 gears but my balls gave up after 3rd. Ant wants to tune to 10000 after the Tango1 PR day because the power is still climbing at 9000.Wolf ECUs rock.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-613402
ND4SPD ran at the plex today.
Ant did one recce run then went out for a big go but the Gearbox spat the dummy.The good news is that the car ran 6/10s faster to 500ft than its low 11s best so a 10 is a walk in the park if we can get a box to do 1 pass but the Dog box has just gone to the top of the list.
https://www.sau.com.au/forums/topic/30182-whales-revenge/#findComment-616695
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
