Ive been re-tuning my car for summer driving, and have been strugling with issues steming from the Air temp corrections. Basically ive found that I can get a perfect tune during the day, or at night, but not both. The problems appear to be stemming from 2 area's.
Firstly, the air temp corrections in Setting 2 dont seem to be having an effect (or my understanding of how these values apply to the base map is wrong).
Secondly, the air temp sensor location (in the plenum in an R34 GTR) seems to be getting heat soaked when stuck stationary in traffic, and it takes sustained driving at speeds above 80km/h to rapidly re-cool that sensor sufficently so that the engine isnt being over-fueled again.
The actual engine temps are being reported as being at the lowest 79 degrees and a peak of 85 degrees when stuck in traffic in the middle of the day(PWR radiator). If the car is tuned in the middle of the day, as air density is lower (hotter air) the fueling requirements are less. However the same tune at night is as much as 0.5 to 0.7 AFR incorrect as a result of changes in air density.
A little background....
Im tuning with a Datalogit linked to a 0-5V PLX devices wideband AFR.
Crusing at 80-100km/h in the middle of the day I am seeing air temps around 55-58 degrees. At 60km/h and below when stuck in traffic, air temps are being reported as being as high as 66 degrees. I have seen the temps past 70 if the car is parked when hot and then allowed to heat-soak, and then restarted. Both of these situations are when outside ambient temps are about 36-38 degrees (a scorching hot day).
So can anyone think of what Im doing wrong here? Is it my lack of understanding of how the air temp corrections are implemented in settings 2, or is this just a grin and bear it situation that can't be effectively tuned around?
Also, has anyone ever considered moving the air temp sensor from the plenum to be in the hose, a little further away from the plenum so that it is less suseptable to heat soak, and also possibly updating the sensor so that it is of the new NTC style air temp sensor, so temp changes are more rapidly detected?
Cheers,
Ian
https://www.sau.com.au/forums/topic/301835-pfc-tuning-for-hot-weather/
the PFC will dial in injection correct based on airtemp
it's the PFC saying, the air is hotter, run richer to avoid detonation city
if you take out the correction - that is, unplug the airtemp sensor, or move it
the same airtemp is still going in (ie sub 70deg after sitting there) and the injection will be 1.00 instead of sub 1.10x ish
so it will likely detonate as the airtemp may be too high
so by moving the sensor, you just give the ECU false readings
which in turn wont enable the injection correction for excessive intake temps
which in turn will likely make it ping if the engine is tuned correctly
so your options are
1) tune the car in winter and setup the airtemp correction correctly so that in summer, by design it backs out timing (the PFC supports this on airtemp) and richens up
2) move the sensor, give the ecu false readings and hope it doesn't ping
3) unpiug the sensor and give the ecu no airtemp reading and hope it dosen't ping
I was hoping you'd chime in Paul.
I think I will probably have to go for option 1, and just grin and bear the crappy fuel economy/rich running on a hot day. It just seems that the rate the PFC richen's up the mixtures as temp increases is a little too exponential.
Can you please explain how the INJ vs Air temp + Boost setting on the setting 2 page is supposed to work? Is this only really relivent for when you have a boost control module connected so that the ECU can reference an external map senor too?
Cheers,
Ian
Just had another idea.... I could look at wiring a resistor in parallel with the air temp sensor, so that as the sensor approaches 50 degrees it will only really be repoting 40ish or so. It will take a bit of stuffing around, but since I cant seem to alter the rate at which the AFR's are richened up, tricking the ECU to think that it is further down the scale might work.
The ignition retards vs air temp will still work, and will just need to be tweaked to accomodate the new scale.
Can you adjust the voltage vs temp? Im assuming its a d-jetro. I would consider fitting a different sensor, as i know on an r32 they are the same sensor as the water temp sensor.
No sorry its a MAF sensor version. The car is more or less standard except for a nismo exhaust too. Its no radically modified car by any means. Im just after a better tune. The standard ECU was running 11.5 - 11.2:1 AFR when on boost (on a normal 28 degree day, not the 35+ degree days we are getting at the moment).
Its the same sensor for air and water on the R34's too. The picture I posted of a sensor in the first post is what is used in the wolf/haltech ecu setups, and they react a lot faster. You can actually see temps change when data logging air temps vs boost.
As far as the datalogit forums went, I only found one reference to a guy with an MR2 that had simular issues. He was advised to try a simular sensor upgrade as well, but there was no follow up as to how well it went.
Edited by GTRNUR
I would have thought that the Mass Flow Sensors'd take temperature/density into account ?
Cheers A .
I think its like Paul was saying. The ecu is going into "over protective mother mode" and dumping in a ton of extra fuel to starve off detonation. It just seems that for every degree above 60 degrees the amount of fuel added is at least a 0.100 correction. Tuning in my climate then means I have about 5 degrees of tunable area before the ecu goes into mother mode.
you shouldnt need to, and you definelty shouldnt modify any of the sensors, please don't do that
if you think the PFC is adding in too much fuel when it shouldnt due to airtemp correciton
either adjust the amount of correct, ie less, so if its say 1.095 then try 1.045
or adjust the airtemp range
either will give you the same result
ie less overfueling at a given airtemp
or a higher airtemp thresohold
the key to getting it right will be
if you shift up the airtemp range or lower the injection correciton, do you get pinging (youll see check light come on)
so thats when you know you've gone too far
ie - if you didnt have this airtemp correction or you turned it off, its likely it would ping, so its a good thing, it just sounds like its maybe a touch too sensitive or too much correction
Thanks Paul, i'll have another shot at playing with the air temp INJ corrections. I should have mentioned earlier that I have tried setting these to 1.000, and also very large values in the past, but they didnt seem to have any effect on the AFR or delivered INJ value.
I suppose it is possible that these changes do not come into effect until the engine is driving under load though (like the ignition lock at 20 degrees when at idle), as when I was making these changes I was stationary.
Ive been keeping the knock levels pretty low (<20 at max rpm/boost) and have my threshold for the warning set to 30. I havent noticed any knocking so far. Quite possibly because the ignition is already tuned somewhat retard compared to cooler climates. This will no doubt change in 6 months when it cools down 10-15 degrees though.
Cheers,
Ian
Edited by GTRNUR
yeah check it when you are driving or look at the logs
another way is to view SETTING, ING/INJ
which is the temp adjust screen, check out the Kij and Fin values
these are injection value in real time
unsure if the PFC will show you corrected value (it should)
just got your email, i will look over the file 2nite over a few beers.
edit: actually im playing with it now, i think i have found the load hysteresis settings.
can you email me a afr log? or at least a few known afr points on the map say?
try it at 1.000 on all of them and see if you get consistent afr's under load, if not then something else is causing your problems. you still have ign retard vs air temp which you should use to keep knock levels low at higher temps.
in the sample rb26 file it has the temps at 100, 70 and 40 with the correction at 1.195, 1.117 and 1.000. if your temps getting up to 100 with these settings it'll be adding 20% more fuel ontop of whats already in the map. thats enough to take you from a steady 12:1 down to 9.6:1, way too rich. correct me if i'm wrong but dont most people aim for a steady afr (ie 12:1) under full load regardless of temp then use timing to stop it pinging on hot days? which would make that correction a little too much
Well I went for a quick lap today and have altered the settings for air temp vs INJ on injector 2 as JonnoHR31 has suggested. As Paul had confirmed, these settings 2 air temp corrections have no effect at idle, yet the corrections are applied when driving. So thanks for your assistance guys.
Thanks for your assistance to Trent. Especially offering to look at a map for me in the middle of the xmas break period.
I changed the 70 degree air temp value from 1.147 to 1.050 ish(I think.. that was 6 hrs ago and im in holiday mode!). This seems to have done the trick as the AFR's are no longer diving well into the 11's when on boost. It actually went to 12.0:1 (so it seemed I guessed close).
So I think this has resolved the issue I was having. In the end it was just my lack of understanding about how the corrections are applied. Every ecu sure does work a little diferently and I am finally getting to know the FC's quirks. Now all I need to do is wait till it cools down a bit so I can get a cooler air temp tune into the car, then it will just be a matter of tweaking the air temp corrections... now that I know that they actually do work!
One more question... With the Wolf ECU's that ive tuned in the past, it is possible to re-scale the MAP sensor so the tuning map provides more resolution at the low end of the load scale, and max boost pressure = 100% load on the fuel map. It is also possible to re-set the lowest manifold pressure point to be the zero load point on the map. I hope that makes sense?
Ive noticed that the FC seems to never be able to achieve low enough airflow (at idle or in de-cel) so that the active load point is in the 1st row on the map. Also as the car is only running 0.8 bar, the max load band achieved is only 14 (15 occasionally if I really push it and get a boost spike to 0.85 bar). So essentially I am only able to tune with 13-14 load bands.. Not 20.
Is there a guide somewhere for re-scaling the load points of the FC's map so it is appropriately scaled to the engines operating ranges? The Settings 3 page relating to the MAP airflow sensors allow altering of the airflow curves, but I dont quite understand how the 1-32 points on the air flow curves relate to the 0-20 load points.
Cheers,
Ian
Edited by GTRNUR
Load scaling is fully programmable, right click on the map referrences across the top of the map and select map refferences.
Then got to settings 3 and look @ the left hand table 01-20 is your load points and rpm points :D
as far as my previous post INJ vs IAT (load hysteresis) there are 3 parts to the table (the 1st two are self explanatory) far right column is the load hysteresis and you can change the constarints to suit your application.
i am playing with your map as it has a few holes (peaks and troughs) i only have the demo versin on my travel lappy but i will have my tuning laptop 2moro so will email it 2moro night.
i can set all the load poits if you like but i would really like a afr log if possible, as your load line 14 is super lean in one spot then rich and timing jumps up 4 degrees from 14 to 15. fuel also gets leaner as it goes past 14.
Interpolate it richer down to the bottom line and drop timing off as it travels down too.
as trent said, load point setup is under settings 3
i'd personally leave p01 and p02 the same, then set p20 to the same as p16 or 17 if your reaching 14 and 15. then use the graph function in the bottom right corner to smooth the curve out similar to the way it is with the sample scaling. make sure all of your cells are currently richer and more retarded than the ones above them, so that changing the scaling doesnt make it lean out or knock the first time you put it under load to start tuning.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
