  • Replies 418
Here you go ladies.... It is way better then the Arrows one.
Right click and save as
Renault F1 Testing:
http://grab.orsm.net//update20050428/f1renault.wmv
3.9mb
Great video
Nice clip that one! Does anyone have the early 90's video of the Williams engine dyno footage (I think they where running Renault engines then) Been on TV a few times, havent seen it in ages
downloading now! Farken quick guys!
Reason asking is that there is a cool video on the Renault F1 site, but you cant download it, its only a stream it
if you want to download streaming video, google a program called "CoCsoft" (really tragic name, i know)
it can download streaming video except for java and there is a 15 day trial limit i think
I just got the whole season 4 of 24 in hd tv off torrents and the latest season of chappell show!!! 24 finished airing in ameica over 6 months ago
Torrents rock!!
HAhah F#CK oath hey... When you say you got 24 in HD TV? What resolution is it. True HD TV is 1920 * 1080 & I'm still yet to find video at this resolution or get a HDTV card so i can use my 23" 1920 * 1200 to it's full advantage :Pimp2:
Not sure havent watched it all yet but its about 8.7gig worth for 24 episodes
Its labeled hd tv xvid
Ahhh yeah, if your a specific asshole like myself you'd criticise them for false labelling. I'd guess the resolution 'like most of the other TV torrents' would be around 720px wide, which is still pretty nice & better than 'normal' TV. In Digital though Standard Defininition is actually like 1024px & HD is 1920px wide :drooling: It's funny that Digital HDTV resolution is so high that not even the next generation of DVD which is DVD-HD isnt even that high. DVD-HD is only going to be around 1440 or under I think. I know it's not anywhere up near 1920px. Things arnt final though, hopefully DVD-HD will make it up to 1920 * 1080px.
My cousin is the torrent king and has all the latest series of every show airing in Australia and access to all private torrent sites which has a shitload more stuff than torrentspy or mininova.
U can get the pure HD res ones but each 1hr episode is nearly 1gig so no 1 cbf downloading 24gig for all episodes.
option_d1_vol135
http://gear.lettlurt.no:6969/stats.html?in...f67b0305b47a033
OPTION AUGUST 2005 VOL-136
http://gear.lettlurt.no:6969/stats.html?in...930d23ec7a16b52
downloading them atm, dunno if they have english subtitle... will post again as soon as i find out.
U can get the pure HD res ones but each 1hr episode is nearly 1gig.
That's fine by me! If you happen to find any pure HD Tv shows could you please flick me a link. I'd love to watch something at a massive res like that. 1 GB for 1 episode would be a good indication for true HD I think :D
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
