  • Replies 521
Where's a decent place to get under bonnet grey matt paint for a BNR32 stadnard dark grey skyline?
I dont want ot fix outside scratches - want to touch up the engine bay before refitting the turbines
The underbonnet paint should be the same as the exterior. Give me the paint code and I can get a tube in from Japan.
Ken
https://www.sau.com.au/forums/topic/30197-darwin/page/12/#findComment-973529
he he , who owns the stocko red r33 gtst, that tryed to race me at the lights in the city last night about 11.00pm ?   was funny lol
Obviously wasnt me. I would have won. Chuckles. I hear you have a phone for sale but apparently it's a bit of a shitter! HAHAHAHAHAH
CUL8R
Ken
https://www.sau.com.au/forums/topic/30197-darwin/page/12/#findComment-986361
hey ken baby ..... the forums are back online lol
oh oh  and nice tow bar mate, might get 1 myself to tow the jet ski 1 day !
Jetski, Manton Dam, BBQ, Suds - sounds like a cruise day to me!!
Just to let everyone know, my wife and I had a little baby girl yesterday at 4pm. Caitlin Sarah May weighed 7lb 10z. Both Lisa and Caitlin are doing really well.
CU
Ken
https://www.sau.com.au/forums/topic/30197-darwin/page/12/#findComment-990091
  • 1 month later...
  • 1 month later...
Yea same Ken well done
I'll have to come see her some day
I talked to TPL about dump do you have the gaskets for both ends of the dump pipe as it would make it a whole lot easier to make, I'll get the price later but it shouldn't be much at all
Mate he should be able to take an outline of both ends, take some photos/measurements and make the pipe. I dont have a gasket or either end of the dump sorry.
Best of luck, what was his price btw??
Cheers m8,
Ken
https://www.sau.com.au/forums/topic/30197-darwin/page/12/#findComment-1087644
  • 3 weeks later...
