ok so start of this week i set out to replace all the coolant hoses below and into the intake manifold
i've done that relatively issue free
finished putting it back together today i go to kick it over and it won't start. the starter goes but that's about it
this is what i have done so far:
checked there is fuel pressure (which i hilariously copped in the face)
checked all the vaccum hoses etc
used new genuine gaskets for both parts of the intake manifold
been over everything with a multi-meter - everything has power; spark plugs, fuel injectors, ignitor box, afm
checked spark plugs - ok (changed them not that long ago)
checked all fuses
i did manage to short out on the starter motor when i was doing up the bolts under the plenum (should had d/c'ed the battery, i know)
so i thought maybe the ecu is fooked, luckily enough i have a spare one from an old project i was going to undertake i plugged it in and it's the same
i tried just starting without any ecu and it's exactly the same as trying to start it with an ecu, starter turns over but there is just no combustion..
even have a video of me trying to kick it over:
any help would be awesome thanks
Edited by mystery_kid
https://www.sau.com.au/forums/topic/302085-possible-electrical-issue/
i've just been made aware that the fuel lines are on the wrong way lolz fuel out goes through the fpr not the other way around. I'll get onto it tomorrow morning
That would have been my first question.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
