Hey guys,
Im in need of some help, im actually from brisbane and im in the market for a GTR and i have found one that i really want. Basically i got it inspected with the usual compression and leak down tests completed etc and it failed how ever the owner of the car feels that the inspection is not accurate and is happy for another inspection. He does not mind where the car is taken he just believes that it deserves another inspection, as it has already cost me $250.00 for the first inspection im really hoping that this next inspection is more accurate. So what im asking is if anyone feels that they are mechanically capable or knows of anyone that is onto it when it comes to GTR's than i would appreciate your help im willing to pay what ever is required to get this car checked out im really desperate as im on the other side of australia.
Drewe
0413 224 081 :)
https://www.sau.com.au/forums/topic/302193-please-help/
You posted this thread in the W.A section so I assume that you are buying a GTR from over here?
If I were you I'd look in the consolidate workshop thread and find a workshop that is close to the dude and get them to do a compression test etc..
https://www.sau.com.au/forums/topic/302193-please-help/#findComment-5012767
If it was checked by a reputable workshop the first time around and failed, why would a 2nd test be any different beside you spending more money?
If your so keen to have it re-inspected, as Lukas said check the consolidated workshop thread
https://www.sau.com.au/forums/topic/302193-please-help/#findComment-5013066
If he is so convinced it is ok, you tell him wear to take it and he can pay and if it comes back ok then buy it??
Sounds fair to me....
Just make sure you get it i some were reputable that you can/will trust and that they can back up there claims in writing....
Edited by GODZ1LLA
https://www.sau.com.au/forums/topic/302193-please-help/#findComment-5013373
Guest
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
