Hello everyone. I am in need of a new lock set with keys for a 1991 R32 GTR. Door, Trunk, and Ignition.
I live in the states and am not able to get the parts here. Do they still sell these replacement parts at nissan in AU?
My keys have mysteriously gone missing and I suspect foul play so I want to get all the locks changed. Please let me know if anyone knows where I could get these parts.
Thanks guys.
https://www.sau.com.au/forums/topic/302511-r32-lock-set/
Thanks guys.
I doubt the genuine parts will be cheaper than re-keying.
Give Crows Nest Nissan a call after about 8.30am local time (i.e. in about an hour or so), when I've needed genuine spares they've been most helpful. You'll need your VIN.
Cheers,
Saliya
https://www.sau.com.au/forums/topic/302511-r32-lock-set/#findComment-5016533
Cheers,
Saliya
Thanks for the info. Trying to get parts here is a pain. luckily a few guys in Canada are running around with skylines.
I'll give them a try. Know any other shops there that can cut a new key from the VIN?
https://www.sau.com.au/forums/topic/302511-r32-lock-set/#findComment-5016674
pm'd i can help out
Hey man very interested. I cannot PM because my thread count is too low, only found this website a little while ago...Stinks too cause this site has everything you could possibly want to know about these cars.
Please PM me your email address and we can work this out.
Thanks
https://www.sau.com.au/forums/topic/302511-r32-lock-set/#findComment-5018210
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
